| cooper951 |
Oct 3 2015, 12:57 PM
Member ![]() ![]() Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
The headlights on my new-to-me 914 are really dim. Anybody have a replacement brand they are crazy about?
| '73-914kid |
Oct 3 2015, 03:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Clean the grounds in the front trunk next to the headlight motors. Remove, wire brush, the replace. This will make some improvement, but most likely not enough to bring them up to snuff IMO.
A good H4, with a good 55/60W H4 bulb should make things livable. |
| cpavlenko |
Oct 3 2015, 04:01 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Clean the grounds in the front trunk next to the headlight motors. Remove, wire brush, the replace. This will make some improvement, but most likely not enough to bring them up to snuff IMO. A good H4, with a good 55/60W H4 bulb should make things livable. ?, can u use the same relays for the H4. |
cooper951 Headlight bulb replacement Oct 3 2015, 12:57 PM
Dion Hi, not knowing what lights you are running,
I... Oct 3 2015, 02:16 PM
rmdinmd depends on how much you want to spend. I bought ... Oct 3 2015, 02:32 PM
'73-914kid You can with the smaller wattage bulbs. I would no... Oct 3 2015, 04:06 PM
cpavlenko
You can with the smaller wattage bulbs. I would n... Oct 3 2015, 04:10 PM
'73-914kid
The headlights on my new-to-me 914 are really dim... Oct 3 2015, 04:32 PM
Dtjaden I've also installed the GE Nighthawk LED headl... Oct 3 2015, 07:45 PM
Sandy Teener Another vote for ge nighthawks, plug and play, les... Oct 4 2015, 11:34 AM
Harpo :agree:
Get the night hawks Oct 4 2015, 05:43 PM
cpavlenko Okay, so what headlamp was on stock 71 914. Trying... Oct 4 2015, 07:03 PM
Dion
Okay, so what headlamp was on stock 71 914. Tryin... Oct 4 2015, 07:14 PM
cpavlenko
Okay, so what headlamp was on stock 71 914. Tryi... Oct 4 2015, 07:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:29 AM |
