| Allan |
Sep 20 2004, 02:03 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Trying to pull the flywheel and noticed that the bolts seemed to have been ground down. Would someone do this so the flywheel could be surfaced beyond minimum specs. and the clutch would still clear. Also, what are the bolts made of? Looks like brass.
| Allan |
Sep 20 2004, 02:44 PM
QUOTE(SLITS @ Sep 20 2004, 12:42 PM) Cold steel chisel and BFH to get them turning. I'm gonna try that first and see what happens. And I will be replacing everything. |
Headrage Flywheel Bolts Sep 20 2004, 02:03 PM
SirAndy ... Sep 20 2004, 02:07 PM
Brad Roberts The 4 spring discs hit the bolt heads after machin... Sep 20 2004, 02:31 PM
Headrage Great. Now the problem is getting them out. Ther... Sep 20 2004, 02:32 PM
Brad Roberts I'm betting you will end up replacing that fly... Sep 20 2004, 02:34 PM
SLITS ... Sep 20 2004, 02:42 PM
Headrage I was looking at Pelican for replacement flywheel ... Sep 20 2004, 04:12 PM
Headrage HOOORAY!! Got the bolts out and flywhell o... Sep 20 2004, 05:06 PM
SLITS End play is what you are asking about - 0.003 - 0.... Sep 20 2004, 05:15 PM
Cap'n Krusty Gotta torque the flywheel back on , WITH the shims... Sep 20 2004, 05:27 PM
Headrage Is end play adjusted with flywheel shims alone or ... Sep 20 2004, 05:43 PM
Cap'n Krusty Just the shims. Of course, if the bearing is movi... Sep 20 2004, 07:35 PM
Headrage I really appreciate the info. on this stuff. Bein... Sep 20 2004, 08:07 PM
SLITS Cap'n - don't you torque the flywheel with... Sep 20 2004, 09:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 12:04 PM |
