> Clutch won't disengage, I should know this, but I don't
Rhodes71/914
post Sep 20 2004, 03:47 PM
Glacier
Hey all, I tried so hard not to ask this question but finaly broke down. I am currently in the process of getting a 2.0L with tail-shifter tranny ready to put in the car. It looks like it is going to be a while before it is ready and I want to drive the car some. Here is the skinny:
1971 1.7L, FI, tail-shifter. Engine runs clutch won't disengage.
There is tension on the clutch pedal when depressed, and the fork moves at the trans. I have tried adjusting, and with the adjustment all the way and clutch is still engaged.
Could it be the throw-out bearing?
I know I should just drop the trans and take a look, just wandering with all the wisdom here if anybody has some ideas for me.
Downunderman
post Sep 20 2004, 04:09 PM
Region Association: Australia and New Zealand
This happened to me a while ago. Assuming the release mechanism is ok you will likely find that the clutch disc is stuck to the flywheel. Put it in 3rd gear with the engine switched off, get in the car, depress the clutch and have a few frineds rock it back and forth. You will know when it unsticks.
Rhodes71/914   Clutch won't disengage   Sep 20 2004, 03:47 PM
Howard R   This happened to me a while ago. Assuming the rel...   Sep 20 2004, 04:09 PM
2-OH!   See the thread today's date about flywheel bol...   Sep 20 2004, 04:51 PM
Rhodes71/914   Have read the thread, can't figure out how it...   Sep 20 2004, 05:21 PM
Joe Ricard   When you pull the transaxle off you need to look a...   Sep 20 2004, 08:53 PM
Rog914   Had a friend that had the same problem only with a...   Sep 20 2004, 09:18 PM
2-OH!   If the flywheel is worn enough and been resurfaced...   Sep 21 2004, 10:14 AM
Rhodes71/914
- Lo-Fi Version Time is now: 5th July 2025 - 08:54 PM
