trunk hinge replcement |
srozick |
Oct 13 2015, 01:38 PM
Newbie Group: Members Posts: 7 Joined: 11-October 15 From: Pittsburgh Member No.: 19,254 Region Association: None |
I need to replace the right hinge for my trunk lid and found the Porsche 914 JWest Trunk Hinge Pivot as an option. No welding. Has anyone used this replacement part?
thanks |
JWest |
Oct 15 2015, 10:51 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I do not recommend welding the kit in place.
There is a second plate that goes in the fenderwell. This sandwiches the original (thin and usually fatigued) metal, reinforcing it and clamping the mount in place. If it is welded it will probably crack at the junction of the weld and the thinner metal, just like the original. |
DRPHIL914 |
Oct 15 2015, 11:03 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I do not recommend welding the kit in place. There is a second plate that goes in the fenderwell. This sandwiches the original (thin and usually fatigued) metal, reinforcing it and clamping the mount in place. If it is welded it will probably crack at the junction of the weld and the thinner metal, just like the original. I have to do this to mine and I have the kit already. can I get it mounted with out having to remove the trunk lid and torsion bars completely? Phil |
Lo-Fi Version | Time is now: 6th June 2024 - 04:15 AM |
