Monday, 11 August 2025 |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Do I need a special clutch/pressure plate for a pull type clutch system I'm assembling for my 911 conversion?
Will this work? The trans is a '70-71' I've been told. But, I'm not familiar with this stuff. Thanks for the help. http://www.ebay.com/itm/Porsche-911-65-69-...ecAAOSwhcJWFxS7 |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,923 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Lawrence, is this all for Speedy?
Has the diff ring gear been flipped? ... 914 nose-cone and side-shift? Also, post the #s stamped on the top rib of the transaxle. If it's a '70/'71, it should be one of the following: 911/01 (standard) or ... 911/80\ 911/81 | 911/82. > (with 904 main shaft) 911/83 | 911/84/ Curious why you want to use a 911/xx trans (IMG:style_emoticons/default/confused24.gif) ... but a side-shift 901 is good for up to about 250 HP if you're not too hard on it. If the '70/'71 911 transaxle has been set up for a 914, you'll need the following [expensive] parts (Pelican #s & prices - new): 911-102-201-12 flywheel (& 6 bolts) - approx. $400. 911-116-239-04 ring gear (& 9 bolts) approx $150. 911CP-7071N - Pressure plate, 225mm disc & T/O bearing (kit) approx $900. + the other misc. parts like Clay mentioned above. Personally, I'd stick with the 914's 901 trans ... you'd be way ahead of the game. |
Lo-Fi Version | Time is now: 11th August 2025 - 03:51 AM |
