> GT cooler install, Setrab unit from PMS
rtalich
post Oct 17 2015, 10:48 AM
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted?
I have a few ideas of how I want to mount... just would like to see what others have done. Thanks!
naro914
post Oct 19 2015, 08:27 AM
Losing my mind...
We went a different route with Huey because we drive him for trips and want to use the front trunk area. We got a flatter style cooler and mounted it on the floor, that way the air is not heated up until it passes through the cooler and out, and the shroud does not get hot thus heating up everything in the front trunk (like the beer cooler that fits nicely up there!!). It also allows for a much flatter shroud meaning you have more open depth to use, but it takes up more of the floor space...so a trade off...
Unfortunately I don't have a picture of it (for some reason??) and its currently at the shop to get the rear suspension fixed. If I can sneak over there and get a few pics, I will
For Papa Smurf, we fabricated a bracket system to vent it out the hood...
stownsen914
post Oct 19 2015, 09:16 AM
Whatever you do, make sure the actual surface area of the air exit from your trunck is at least the same as the surface area of your cooler. So if the dimensions of your cooler that face the air source are 24 x 6, for example, then the exit must be at least 144 sq. inches. 1.5 times the cooler size is even better. The louvered panels shown in the thread look like a nice, clean option, but I'll bet the actual louver openings are nowhere near the size needed to exit air for a large cooler.
Apologies if I am stating the obvious, but if the exit from your cooler is restrictive, the air will stack up in your duct and basically won't even enter your duct opening (hence limited cooling), and will defeat much of the purpose of a front mounted cooler setup.
Scott
rtalich   GT cooler install   Oct 17 2015, 10:48 AM
Steve   I used the pbase site as a guide when I did mine. ...   Oct 17 2015, 11:07 AM
23e Heure   I'm bookmarking this thread... Has anyone fit...   Oct 18 2015, 02:26 PM
mepstein   I'm bookmarking this thread... Has anyone fi...   Oct 18 2015, 03:14 PM
23e Heure   I had a scroll through the PMS pics, and sorry if ...   Oct 18 2015, 03:41 PM
mepstein   I wanted max air flow so I asked scotty to make me...   Oct 18 2015, 04:10 PM
rtalich   Thanks for the info and pics so far!! All ...   Oct 18 2015, 07:21 PM
Cairo94507   :popcorn:   Oct 19 2015, 06:48 AM
naro914   We went a different route with Huey because we dri...   Oct 19 2015, 08:27 AM
stownsen914   Whatever you do, make sure the actual surface area...   Oct 19 2015, 09:16 AM
SirAndy   Whatever you do, make sure the actual surface area...   Oct 19 2015, 12:53 PM
mepstein   Whatever you do, make sure the actual surface are...   Oct 19 2015, 01:29 PM
SirAndy   [quote name='SirAndy' post='2254166' date='Oct 19 ...   Oct 19 2015, 01:36 PM
stownsen914   That would be true in a static environment. Howe...   Oct 19 2015, 01:41 PM
SirAndy   Granted we are talking about a supplemental oil co...   Oct 19 2015, 01:49 PM
naro914   Scott's right. Obviously, air expands when hea...   Oct 19 2015, 09:33 AM
anderssj   Really nice work on the louvers and Al shroud. Un...   Oct 19 2015, 10:21 AM
RobW   What's the total damage for cooler, shroud, oi...   Oct 19 2015, 11:36 AM
23e Heure   What's the total damage for cooler, shroud, o...   Oct 19 2015, 12:23 PM
23e Heure   That custom made one in mepstein's post above ...   Oct 19 2015, 12:47 PM
Cairo94507   Now you guys have me worried. I have the exact sa...   Oct 19 2015, 01:10 PM
mepstein   Now you guys have me worried. I have the exact s...   Oct 19 2015, 01:27 PM
scotty b   Now you guys have me worried. I have the exact ...   Oct 20 2015, 10:40 AM
rtalich   I find it really hard to believe that nobody else ...   Oct 20 2015, 07:31 AM
naro914   I find it really hard to believe that nobody else...   Oct 20 2015, 07:41 AM
stownsen914   I do...the exact one on Papa Smurf...but it's...   Oct 20 2015, 10:08 AM
ConeDodger   I find it really hard to believe that nobody else...   Oct 24 2015, 10:15 AM
rtalich   I find it really hard to believe that nobody els...   Oct 24 2015, 01:29 PM
ConeDodger   [quote name='ConeDodger' post='2256328' date='Oct...   Oct 25 2015, 04:50 AM
rtalich   [quote name='ConeDodger' post='2256328' date='Oc...   Oct 25 2015, 09:52 AM
bigkensteele   I find it really hard to believe that nobody els...   Oct 26 2015, 06:53 PM
mepstein   [quote name='ConeDodger' post='2256328' date='Oct...   Oct 26 2015, 08:41 PM
Steve   [quote name='bigkensteele' post='2257202' date='O...   Dec 8 2015, 11:19 PM
Dave_Darling   Why is the shroud covered by a shroud? Not sure ...   Nov 9 2015, 03:25 PM
rtalich   Thanks! I will post pics of my install when I...   Oct 20 2015, 09:51 AM
horizontally-opposed   Slickest setup I've seen on a street car was d...   Oct 20 2015, 10:09 AM
JmuRiz   Slickest setup I've seen on a street car was ...   Oct 20 2015, 10:21 AM
echocanyons   I asked Mark to engineer and install this one for ...   Oct 20 2015, 10:45 AM
mepstein   I asked Mark to engineer and install this one for...   Oct 20 2015, 12:04 PM
naro914   I asked Mark to engineer and install this one for...   Oct 21 2015, 10:22 AM
396   I asked Mark to engineer and install this one fo...   Oct 23 2015, 08:51 AM
maf914   I asked Mark to engineer and install this one for...   Oct 23 2015, 06:32 AM
JmuRiz   Wow, that is VERY cool...spare tire, oil cooling a...   Oct 20 2015, 01:20 PM
naro914   Here's the inlet/outlet side of the cooler now...   Oct 21 2015, 10:26 AM
rtalich   I'd like to install these rubber isolators in ...   Oct 23 2015, 07:21 PM
rtalich   I'd like to install these rubber isolators in...   Oct 26 2015, 04:58 PM
Cairo94507   Contour the rubber grommet?   Oct 23 2015, 08:10 PM
SirAndy   Add a metal spacer of sorts to the chassis that al...   Oct 23 2015, 08:49 PM
rhodyguy   I'm confused. Very.   Oct 25 2015, 12:27 PM
mepstein   I'm confused. Very. Boys have a penis Girls...   Oct 25 2015, 12:39 PM
Cairo94507   What???? :stooges:   Oct 25 2015, 08:09 PM
rtalich   Don't have a lot of time to work on my car... ...   Nov 9 2015, 11:01 AM
rtalich   More progress...   Nov 17 2015, 10:40 AM
Racer Chris   Those don't look like -12   Nov 17 2015, 10:49 AM
rtalich   Those don't look like -12 They are -12AN li...   Nov 17 2015, 11:40 AM
Racer Chris   Those don't look like -12 They are -12AN l...   Nov 17 2015, 11:47 AM
rtalich   Slowly but surely making progress. I got everythi...   Dec 8 2015, 08:03 PM
rtalich   Well... Finally got the car running again. Took i...   Jun 30 2016, 09:25 AM
23e Heure   Somebody posted shots on a similar thread of the r...   Jul 8 2016, 04:42 AM
ConeDodger   Mine isn't light ivory, but I did the same coo...   Jul 8 2016, 08:39 AM
23e Heure   Mine isn't light ivory, but I did the same co...   Jul 20 2016, 03:36 PM
rgalla9146   Even as we speak.   Jul 8 2016, 11:38 AM
Harpo   Even as we speak. I was asking McMark about tha...   Jul 10 2016, 01:55 PM
Mueller   Even as we speak. Neat, is it going to have a ...   Jul 20 2016, 03:45 PM
rgalla9146   Even as we speak. Neat, is it going to have a...   Jul 20 2016, 04:47 PM
Mitox   [quote name='Mueller' post='2374037' date='Jul 20...   Jul 21 2016, 06:05 PM
rgalla9146   Even as we speak. Neat, is it going to have a...   Jul 20 2016, 04:49 PM
barefoot   [quote name='Mueller' post='2374037' date='Jul 20...   Jul 21 2016, 04:14 PM
echocanyons   Very cool! Looking forward to the completed v...   Jul 8 2016, 08:38 PM
rgalla9146   Very cool! Looking forward to the completed ...   Jul 9 2016, 05:59 AM
JmuRiz   VERY cool shroud!   Jul 10 2016, 06:38 PM
maf914   Very nice fiberglass work. How was the duct molde...   Jul 21 2016, 09:02 AM
rgalla9146   Very nice fiberglass work. How was the duct mold...   Jul 21 2016, 09:53 AM
Cairo94507   That looks like an excellent solution and keeps on...   Jul 21 2016, 03:59 PM
98101   I've got the Patrick Motorsport / Setrab auxil...   Nov 22 2017, 08:38 PM
mepstein   I've got the Patrick Motorsport / Setrab auxi...   Nov 22 2017, 08:58 PM
Dave_Darling   Magnets, coroplast (corrugated plastic sign materi...   Nov 22 2017, 09:13 PM
- Lo-Fi Version Time is now: 6th March 2026 - 12:54 AM
