| rtalich |
Oct 17 2015, 10:48 AM
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted? I have a few ideas of how I want to mount... just would like to see what others have done. Thanks! Attached image(s)
| naro914 |
Oct 19 2015, 08:27 AM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
We went a different route with Huey because we drive him for trips and want to use the front trunk area. We got a flatter style cooler and mounted it on the floor, that way the air is not heated up until it passes through the cooler and out, and the shroud does not get hot thus heating up everything in the front trunk (like the beer cooler that fits nicely up there!!). It also allows for a much flatter shroud meaning you have more open depth to use, but it takes up more of the floor space...so a trade off...
Unfortunately I don't have a picture of it (for some reason??) and its currently at the shop to get the rear suspension fixed. If I can sneak over there and get a few pics, I will For Papa Smurf, we fabricated a bracket system to vent it out the hood... |
| stownsen914 |
Oct 19 2015, 09:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Whatever you do, make sure the actual surface area of the air exit from your trunck is at least the same as the surface area of your cooler. So if the dimensions of your cooler that face the air source are 24 x 6, for example, then the exit must be at least 144 sq. inches. 1.5 times the cooler size is even better. The louvered panels shown in the thread look like a nice, clean option, but I'll bet the actual louver openings are nowhere near the size needed to exit air for a large cooler.
Apologies if I am stating the obvious, but if the exit from your cooler is restrictive, the air will stack up in your duct and basically won't even enter your duct opening (hence limited cooling), and will defeat much of the purpose of a front mounted cooler setup. Scott |
| SirAndy |
Oct 19 2015, 12:53 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,454 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Whatever you do, make sure the actual surface area of the air exit from your trunck is at least the same as the surface area of your cooler. So if the dimensions of your cooler that face the air source are 24 x 6, for example, then the exit must be at least 144 sq. inches. 1.5 times the cooler size is even better. The louvered panels shown in the thread look like a nice, clean option, but I'll bet the actual louver openings are nowhere near the size needed to exit air for a large cooler. Apologies if I am stating the obvious, but if the exit from your cooler is restrictive, the air will stack up in your duct and basically won't even enter your duct opening (hence limited cooling), and will defeat much of the purpose of a front mounted cooler setup. That would be true in a static environment. However, if you increase air speed after the cooler you can expel that same air just as efficiently with a smaller size outlet. Which is exactly what the louvers do ... (IMG:style_emoticons/default/shades.gif) |
| stownsen914 |
Oct 19 2015, 01:41 PM
That would be true in a static environment. However, if you increase air speed after the cooler you can expel that same air just as efficiently with a smaller size outlet. Which is exactly what the louvers do ... (IMG:style_emoticons/default/shades.gif) It is true that louvers create a pressure differential where one would not otherwise exist, e.g. at the top of a prototype fender. My statement earlier about exit sizing assumes good air flow into a low pressure area. I'm curious to know how louvers totalling what look like maybe 1 sq. inch each can match flow of a large (100-200 sq. inch) opening into a low pressure area with a lip at the leading edge ... Granted we are talking about a supplemental oil cooler here (and possibly a street application), so ideal exit flow may not be needed. In such a case louvers may be good enough. |
| SirAndy |
Oct 19 2015, 01:49 PM
Granted we are talking about a supplemental oil cooler here (and possibly a street application), so ideal exit flow may not be needed. In such a case louvers may be good enough. My 3.6L has no engine cooler, all i have is the front mounted cooler and the air exits through a shroud and out the *top* trough several "louvers" in the hood. The total surface area for the louvered openings is about the same as the area of the inlet. While moving, the cooler is actually too efficient and unless i'm running a full race session on the track my car has trouble getting up to operating temps. That's on a 80+ California day ... The only time i see the temps approaching 220 is after a long drive on a hot day (90+) when i get stuck in traffic and have no air flow over the cooler (no fans). In normal operating mode, my oil temps hover right around 180 ... (IMG:style_emoticons/default/shades.gif) |
rtalich GT cooler install Oct 17 2015, 10:48 AM
Steve I used the pbase site as a guide when I did mine.
... Oct 17 2015, 11:07 AM
23e Heure I'm bookmarking this thread...
Has anyone fit... Oct 18 2015, 02:26 PM
Has anyone fi... Oct 18 2015, 03:14 PM
23e Heure I had a scroll through the PMS pics, and sorry if ... Oct 18 2015, 03:41 PM
mepstein I wanted max air flow so I asked scotty to make me... Oct 18 2015, 04:10 PM
rtalich Thanks for the info and pics so far!! All ... Oct 18 2015, 07:21 PM
Cairo94507 :popcorn: Oct 19 2015, 06:48 AM
Whatever you do, make sure the actual surface are... Oct 19 2015, 01:29 PM
SirAndy [quote name='SirAndy' post='2254166' date='Oct 19 ... Oct 19 2015, 01:36 PM
naro914 Scott's right. Obviously, air expands when hea... Oct 19 2015, 09:33 AM
anderssj Really nice work on the louvers and Al shroud.
Un... Oct 19 2015, 10:21 AM
RobW What's the total damage for cooler, shroud, oi... Oct 19 2015, 11:36 AM
23e Heure
What's the total damage for cooler, shroud, o... Oct 19 2015, 12:23 PM
23e Heure That custom made one in mepstein's post above ... Oct 19 2015, 12:47 PM
Cairo94507 Now you guys have me worried. I have the exact sa... Oct 19 2015, 01:10 PM
Now you guys have me worried. I have the exact s... Oct 19 2015, 01:27 PM
scotty b
Now you guys have me worried. I have the exact ... Oct 20 2015, 10:40 AM
rtalich I find it really hard to believe that nobody else ... Oct 20 2015, 07:31 AM
naro914
I find it really hard to believe that nobody else... Oct 20 2015, 07:41 AM
stownsen914
I do...the exact one on Papa Smurf...but it's... Oct 20 2015, 10:08 AM
ConeDodger
I find it really hard to believe that nobody else... Oct 24 2015, 10:15 AM
rtalich
I find it really hard to believe that nobody els... Oct 24 2015, 01:29 PM
ConeDodger
[quote name='ConeDodger' post='2256328' date='Oct... Oct 25 2015, 04:50 AM
rtalich
[quote name='ConeDodger' post='2256328' date='Oc... Oct 25 2015, 09:52 AM
bigkensteele
I find it really hard to believe that nobody els... Oct 26 2015, 06:53 PM
[quote name='ConeDodger' post='2256328' date='Oct... Oct 26 2015, 08:41 PM
Steve
[quote name='bigkensteele' post='2257202' date='O... Dec 8 2015, 11:19 PM
Dave_Darling
Why is the shroud covered by a shroud? Not sure ... Nov 9 2015, 03:25 PM
rtalich Thanks! I will post pics of my install when I... Oct 20 2015, 09:51 AM
horizontally-opposed Slickest setup I've seen on a street car was d... Oct 20 2015, 10:09 AM
JmuRiz
Slickest setup I've seen on a street car was ... Oct 20 2015, 10:21 AM
echocanyons I asked Mark to engineer and install this one for ... Oct 20 2015, 10:45 AM
I asked Mark to engineer and install this one for... Oct 20 2015, 12:04 PM
naro914
I asked Mark to engineer and install this one for... Oct 21 2015, 10:22 AM
396
I asked Mark to engineer and install this one fo... Oct 23 2015, 08:51 AM
maf914
I asked Mark to engineer and install this one for... Oct 23 2015, 06:32 AM
JmuRiz Wow, that is VERY cool...spare tire, oil cooling a... Oct 20 2015, 01:20 PM
naro914 Here's the inlet/outlet side of the cooler now... Oct 21 2015, 10:26 AM
rtalich I'd like to install these rubber isolators in ... Oct 23 2015, 07:21 PM
rtalich
I'd like to install these rubber isolators in... Oct 26 2015, 04:58 PM
Cairo94507 Contour the rubber grommet? Oct 23 2015, 08:10 PM
SirAndy Add a metal spacer of sorts to the chassis that al... Oct 23 2015, 08:49 PM
rhodyguy I'm confused. Very. Oct 25 2015, 12:27 PM
I'm confused. Very.
Boys have a penis
Girls... Oct 25 2015, 12:39 PM
Cairo94507 What???? :stooges: Oct 25 2015, 08:09 PM
rtalich Don't have a lot of time to work on my car... ... Nov 9 2015, 11:01 AM
rtalich More progress... Nov 17 2015, 10:40 AM
Racer Chris Those don't look like -12 Nov 17 2015, 10:49 AM
rtalich
They are -12AN li... Nov 17 2015, 11:40 AM
Racer Chris
They are -12AN l... Nov 17 2015, 11:47 AM
rtalich Slowly but surely making progress. I got everythi... Dec 8 2015, 08:03 PM
rtalich Well... Finally got the car running again. Took i... Jun 30 2016, 09:25 AM
23e Heure Somebody posted shots on a similar thread of the r... Jul 8 2016, 04:42 AM
ConeDodger Mine isn't light ivory, but I did the same coo... Jul 8 2016, 08:39 AM
23e Heure
Mine isn't light ivory, but I did the same co... Jul 20 2016, 03:36 PM
rgalla9146 Even as we speak. Jul 8 2016, 11:38 AM
Harpo
Even as we speak.
I was asking McMark about tha... Jul 10 2016, 01:55 PM
Mueller
Even as we speak.
Neat, is it going to have a ... Jul 20 2016, 03:45 PM
rgalla9146
Even as we speak.
Neat, is it going to have a... Jul 20 2016, 04:47 PM
Mitox
[quote name='Mueller' post='2374037' date='Jul 20... Jul 21 2016, 06:05 PM
rgalla9146
Even as we speak.
Neat, is it going to have a... Jul 20 2016, 04:49 PM
barefoot
[quote name='Mueller' post='2374037' date='Jul 20... Jul 21 2016, 04:14 PM
echocanyons Very cool!
Looking forward to the completed v... Jul 8 2016, 08:38 PM
rgalla9146
Very cool!
Looking forward to the completed ... Jul 9 2016, 05:59 AM
JmuRiz VERY cool shroud! Jul 10 2016, 06:38 PM
maf914 Very nice fiberglass work. How was the duct molde... Jul 21 2016, 09:02 AM
rgalla9146
Very nice fiberglass work. How was the duct mold... Jul 21 2016, 09:53 AM
Cairo94507 That looks like an excellent solution and keeps on... Jul 21 2016, 03:59 PM
98101 I've got the Patrick Motorsport / Setrab auxil... Nov 22 2017, 08:38 PM
I've got the Patrick Motorsport / Setrab auxi... Nov 22 2017, 08:58 PM
Dave_Darling Magnets, coroplast (corrugated plastic sign materi... Nov 22 2017, 09:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 12:48 AM |
