GT cooler install, Setrab unit from PMS |
rtalich |
Oct 17 2015, 10:48 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted? I have a few ideas of how I want to mount... just would like to see what others have done. Thanks! Attached image(s) |
naro914 |
Oct 19 2015, 08:27 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
We went a different route with Huey because we drive him for trips and want to use the front trunk area. We got a flatter style cooler and mounted it on the floor, that way the air is not heated up until it passes through the cooler and out, and the shroud does not get hot thus heating up everything in the front trunk (like the beer cooler that fits nicely up there!!). It also allows for a much flatter shroud meaning you have more open depth to use, but it takes up more of the floor space...so a trade off...
Unfortunately I don't have a picture of it (for some reason??) and its currently at the shop to get the rear suspension fixed. If I can sneak over there and get a few pics, I will For Papa Smurf, we fabricated a bracket system to vent it out the hood... |
stownsen914 |
Oct 19 2015, 09:16 AM
Whatever you do, make sure the actual surface area of the air exit from your trunck is at least the same as the surface area of your cooler. So if the dimensions of your cooler that face the air source are 24 x 6, for example, then the exit must be at least 144 sq. inches. 1.5 times the cooler size is even better. The louvered panels shown in the thread look like a nice, clean option, but I'll bet the actual louver openings are nowhere near the size needed to exit air for a large cooler.
Apologies if I am stating the obvious, but if the exit from your cooler is restrictive, the air will stack up in your duct and basically won't even enter your duct opening (hence limited cooling), and will defeat much of the purpose of a front mounted cooler setup. Scott |
SirAndy |
Oct 19 2015, 12:53 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Whatever you do, make sure the actual surface area of the air exit from your trunck is at least the same as the surface area of your cooler. So if the dimensions of your cooler that face the air source are 24 x 6, for example, then the exit must be at least 144 sq. inches. 1.5 times the cooler size is even better. The louvered panels shown in the thread look like a nice, clean option, but I'll bet the actual louver openings are nowhere near the size needed to exit air for a large cooler. Apologies if I am stating the obvious, but if the exit from your cooler is restrictive, the air will stack up in your duct and basically won't even enter your duct opening (hence limited cooling), and will defeat much of the purpose of a front mounted cooler setup. That would be true in a static environment. However, if you increase air speed after the cooler you can expel that same air just as efficiently with a smaller size outlet. Which is exactly what the louvers do ... (IMG:style_emoticons/default/shades.gif) |
stownsen914 |
Oct 19 2015, 01:41 PM
That would be true in a static environment. However, if you increase air speed after the cooler you can expel that same air just as efficiently with a smaller size outlet. Which is exactly what the louvers do ... (IMG:style_emoticons/default/shades.gif) It is true that louvers create a pressure differential where one would not otherwise exist, e.g. at the top of a prototype fender. My statement earlier about exit sizing assumes good air flow into a low pressure area. I'm curious to know how louvers totalling what look like maybe 1 sq. inch each can match flow of a large (100-200 sq. inch) opening into a low pressure area with a lip at the leading edge ... Granted we are talking about a supplemental oil cooler here (and possibly a street application), so ideal exit flow may not be needed. In such a case louvers may be good enough. |
SirAndy |
Oct 19 2015, 01:49 PM
Granted we are talking about a supplemental oil cooler here (and possibly a street application), so ideal exit flow may not be needed. In such a case louvers may be good enough. My 3.6L has no engine cooler, all i have is the front mounted cooler and the air exits through a shroud and out the *top* trough several "louvers" in the hood. The total surface area for the louvered openings is about the same as the area of the inlet. While moving, the cooler is actually too efficient and unless i'm running a full race session on the track my car has trouble getting up to operating temps. That's on a 80+ California day ... The only time i see the temps approaching 220 is after a long drive on a hot day (90+) when i get stuck in traffic and have no air flow over the cooler (no fans). In normal operating mode, my oil temps hover right around 180 ... (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 08:01 AM |
