> Pull type clutch question….
Larmo63
post Oct 17 2015, 07:57 PM
Do I need a special clutch/pressure plate for a pull type clutch system I'm assembling for my 911 conversion?
Will this work? The trans is a '70-71' I've been told. But, I'm not familiar with this stuff. Thanks for the help.
http://www.ebay.com/itm/Porsche-911-65-69-...ecAAOSwhcJWFxS7
Larmo63
post Oct 19 2015, 07:01 PM
Do 914 CVs fit the 911/01 output flanges, or am I going to have trouble THERE too? (IMG:style_emoticons/default/headbang.gif)
Larmo63   Pull type clutch question….   Oct 17 2015, 07:57 PM
euro911   Lawrence, you'll need an early 911 flywheel (...   Oct 17 2015, 09:07 PM
rgalla9146   Wait a minute, the trans is a '75 what ? a...   Oct 17 2015, 09:17 PM
euro911   The engine came out of my '67 912-6. The case ...   Oct 17 2015, 09:28 PM
ClayPerrine   A 1975 transmission would be a 915. That clutch a...   Oct 17 2015, 10:13 PM
Larmo63   Update, yes, the engine is a six bolt '69 911E...   Oct 17 2015, 10:57 PM
euro911   Lawrence, is this all for Speedy? Has the diff ri...   Oct 17 2015, 11:45 PM
jcd914   70/71 911 pull type clutch uses a different pressu...   Oct 17 2015, 11:54 PM
Larmo63   Yes, it is a 911/01 tranny rebuilt with /6 gear ra...   Oct 18 2015, 12:27 AM
oldie914   A little history: For the 1970 911 model year, Por...   Oct 18 2015, 02:19 AM
rgalla9146   And now you've got all the dirt. Enough to...   Oct 18 2015, 05:25 AM
ClayPerrine   I have this setup in my six conversion, and have b...   Oct 18 2015, 09:52 AM
Larmo63   Thanks guys, at least I know what to look for now,...   Oct 18 2015, 11:46 AM
Mark Henry   I would have used a 914 trans case*, 6 bolt '6...   Oct 18 2015, 11:06 PM
stownsen914   I have the 70-71 clutch setup in my 914/6 racecar....   Oct 19 2015, 09:23 AM
Larmo63   Do 914 CVs fit the 911/01 output flanges, or am I ...   Oct 19 2015, 07:01 PM
Mark Henry   Do 914 CVs fit the 911/01 output flanges, or am I...   Oct 19 2015, 07:17 PM
euro911   911 axles and CVs are larger and have 6 bolts. You...   Oct 19 2015, 07:19 PM
Mark Henry   I think this is the main reason so many have rec...   Oct 19 2015, 08:57 PM
euro911   Ah ... Mark beat me to the post - while I was stil...   Oct 19 2015, 07:22 PM
rgalla9146   If you go with the pull clutch it will be near imp...   Oct 19 2015, 08:22 PM
ClayPerrine   If you go with the pull clutch it will be near im...   Oct 19 2015, 08:29 PM
Larmo63   The flanges do fit the same CVs I have. I have alr...   Oct 19 2015, 09:23 PM
Steve   Hassle wise, it is easier with a six 2.0-2.7 to us...   Oct 19 2015, 11:52 PM
396   Hassle wise, it is easier with a six 2.0-2.7 to u...   Oct 20 2015, 12:03 AM
rgalla9146   Hassle wise, it is easier with a six 2.0-2.7 to u...   Oct 20 2015, 05:42 AM
Mark Henry   Just to clarify, the '70-'71 trans fro...   Oct 20 2015, 05:39 PM
Larmo63   Yes, I mis-identified it earlier as a 901/01. My t...   Oct 20 2015, 04:18 PM
- Lo-Fi Version Time is now: 11th August 2025 - 06:46 AM
