Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Do I need a special clutch/pressure plate for a pull type clutch system I'm assembling for my 911 conversion?
Will this work? The trans is a '70-71' I've been told. But, I'm not familiar with this stuff. Thanks for the help. http://www.ebay.com/itm/Porsche-911-65-69-...ecAAOSwhcJWFxS7 |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Hassle wise, it is easier with a six 2.0-2.7 to use the 2.0 six flywheel. It mates up with a stock 2.0 six push clutch package and bolts right up to a stock 914 trans. I ran this combo with my 2.7 six for over 10 trouble free years.
When running a 3.0-3.2 you are stuck with a KEP adapter to work with the 914 trans. For a 3.0-3.2 motor the 71 901 trans pull clutch works much better than the KEP adapter. The clutch pedal with the 71 901 trans pull clutch went down like butter. The KEP adapter with stage 2 clutch felt like something was going to snap. This is my opinion based on experience with both transmissions. I ran the KEP adapter for 15 years with a stock 914 trans and my 3.2 motor. I recently upgraded to a 915 gearbox, to get around the clutch issues and get the correct gearing for my 3.2 six. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,792 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Hassle wise, it is easier with a six 2.0-2.7 to use the 2.0 six flywheel. It mates up with a stock 2.0 six push clutch package and bolts right up to a stock 914 trans. I ran this combo with my 2.7 six for over 10 trouble free years. When running a 3.0-3.2 you are stuck with a KEP adapter to work with the 914 trans. For a 3.0-3.2 motor the 71 901 trans pull clutch works much better than the KEP adapter. The clutch pedal with the 71 901 trans pull clutch went down like butter. The KEP adapter with stage 2 clutch felt like something was going to snap. This is my opinion based on experience with both transmissions. I ran the KEP adapter for 15 years with a stock 914 trans and my 3.2 motor. I recently upgraded to a 915 gearbox, to get around the clutch issues and get the correct gearing for my 3.2 six. Just to clarify, the '70-'71 trans from a 911 is identified as the '911' type trans. Before, was the 901, after was the 915. A 914 trans can be converted to a pull type clutch. It requires moving the pivot location for the throw-out -arm and then using all the parts for the '70-'71 clutch. |
Lo-Fi Version | Time is now: 11th August 2025 - 06:52 AM |
