GT cooler install, Setrab unit from PMS |
rtalich |
Oct 17 2015, 10:48 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted? I have a few ideas of how I want to mount... just would like to see what others have done. Thanks! Attached image(s) |
SirAndy |
Oct 23 2015, 08:49 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Add a metal spacer of sorts to the chassis that allows the rubber to be mounted exactly where you're holding it?
Or would that move everything up too high? Just FYI, when i installed my front cooler, i added a U-channel to the bottom (and top) so that the cooler "floats" in it. The U-channel is padded to absorb vibrations. No rubber mounts were harmed during the install ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 06:08 PM |
