GT cooler install, Setrab unit from PMS |
rtalich |
Oct 17 2015, 10:48 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted? I have a few ideas of how I want to mount... just would like to see what others have done. Thanks! Attached image(s) |
rtalich |
Oct 20 2015, 07:31 AM
I find it really hard to believe that nobody else on this website has this particular cooler installed!!
ConeDodger |
Oct 24 2015, 10:15 AM
Apex killer! Group: Members Posts: 23,616 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I find it really hard to believe that nobody else on this website has this particular cooler installed!! I think mine is the same one... Attached image(s) |
rtalich |
Oct 24 2015, 01:29 PM
I find it really hard to believe that nobody else on this website has this particular cooler installed!! I think mine is the same one... Thanks Rob!! Yes that is the same. Any way you could get a close up pic of the cooler mounts? |
ConeDodger |
Oct 25 2015, 04:50 AM
I find it really hard to believe that nobody else on this website has this particular cooler installed!! I think mine is the same one... Thanks Rob!! Yes that is the same. Any way you could get a close up pic of the cooler mounts? Sorry. Not without uninstalling it. Call Mark. He does this the same way with each install for the GT type period correct look installs... |
rtalich |
Oct 25 2015, 09:52 AM
I find it really hard to believe that nobody else on this website has this particular cooler installed!! I think mine is the same one... Thanks Rob!! Yes that is the same. Any way you could get a close up pic of the cooler mounts? Sorry. Not without uninstalling it. Call Mark. He does this the same way with each install for the GT type period correct look installs... Thanks Rob! |
Lo-Fi Version | Time is now: 12th June 2024 - 01:23 AM |
