914 Fuel Cell - new design fits in stock tank location, ...holds 40% more than the alternative available tank |
naro914 |
Oct 15 2015, 04:22 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
With the help of Mike Phillips out in Oregon, we've had Fuel Safe design a fully compliant fuel cell for 914's that fits into the stock tank location and holds 14 gallons vs. the PMS tank that holds only 10.
- All fittings come out the top: Pickup (-8), Return (-6), Vent (-6) - Includes level sending unit that works with the stock gauge (slight wiring adjustment needed at the sending unit connection point) - Includes high pressure pump mounted internal to the cell - Capacity of 14 gallons - Fuel Safe bladder and foam inside - Aluminum outer shell Price is $3,495 plus paypal fees and shipping A few pictures below. The cell comes with the tabs you see on the top front and rear to allow for bracketing/clamping. The clamps you see on the front and rear in the pictures are not included, allowing the owner to determine how they would like to secure the unit. Mike drilled holes directly to the front firewall bulkhead and ran bolts through the top tab to secure it. I preferred making clamps that are bolted to the firewall. |
Maltese Falcon |
Oct 25 2015, 01:13 PM
Advanced Member Group: Members Posts: 4,686 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Hi Bob...do you think that I can run a secondary external pump, in-line to the internal pump? I need to support over 1,000 bhp. Much volume required for the 8 RC injectors.
Good seeing you + Nadine at the Rennsport5 (IMG:style_emoticons/default/smile.gif) Marty |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:45 AM |
