GT cooler install, Setrab unit from PMS |
rtalich |
Oct 17 2015, 10:48 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I know there isn't a right or wrong way to install (or maybe there is). Just would like to know or get idea's from people that have done this particular install. Is there a prefabbed bracket I can buy? Or do I simply bolt this as close to the front as I possibly can? Using isolation mounts of course.
Also, how is the bottom shroud mounted? I have a few ideas of how I want to mount... just would like to see what others have done. Thanks! Attached image(s) |
rtalich |
Oct 23 2015, 07:21 PM
I'd like to install these rubber isolators in this exact spot and as you can see the bottom is not flat. Any ideas of what I can do here? The top brackets are easy... I'll simple use an L bracket.
Thanks, Rob PS - Just using the L piece shown as support so I can a good picture... (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
rtalich |
Oct 26 2015, 04:58 PM
I'd like to install these rubber isolators in this exact spot and as you can see the bottom is not flat. Any ideas of what I can do here? The top brackets are easy... I'll simple use an L bracket. Thanks, Rob PS - Just using the L piece shown as support so I can a good picture... (IMG:style_emoticons/default/beerchug.gif) This is what I've done so far... Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 02:29 PM |
