Need Raby 9590 cam info |
Frank S |
May 6 2015, 04:53 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
Hi there,
I'm about to order parts for my engine rebuild. The plan is to upgrade a 2.0 GA D-Jet engine as following: 2056cc Stroke 71mm (stock) CR 9:1 Raby 9590 cam SSI Heatexchangers Original Muffler The only thing stoping me right now is that I need verify CO2 emissions every 2 years here in Germany. My questions are now: 1. Does this set up idle well and stable at 900-950RPM 2. Does it reach the 3% CO2 spec. in idle I know that a none stock cam should not idle so low, this will be just for the time of the measurement. Without reaching this spec values I not able to register the car here in Germany :-( Thanks and best Regards, Frank |
Highland |
Oct 27 2015, 12:03 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
To get the recommended 14 degrees BTDC at idle is there a recommended distributor or modification?
The best I can do is 6 degrees BTDC at idle with a maximum advance of 30 degrees at 3500+ rpm. |
Jake Raby |
Oct 27 2015, 08:18 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
To get the recommended 14 degrees BTDC at idle is there a recommended distributor or modification? The best I can do is 6 degrees BTDC at idle with a maximum advance of 30 degrees at 3500+ rpm. Then your dizzy has too much built in advance. This must be limited to around 16 degrees, so you can achieve 12-14* at idle, and 28-30* degrees at full advance. This makes a world of difference in idle quality, as well as all around performance, and fuel economy, not to mention CHT and OT control. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:32 PM |
