Beakster |
Member ![]() ![]() Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None ![]() |
I just got my New 914 home late last nite .. Sorry guys for the Dumb ??? But because the guy had a back PORSCHE tail light lens installed .. I don't see that there is a trunk lock release button to open the back trunk .. So now how do I get the back trunk open and were would this now be ?? Thanks (IMG:style_emoticons/default/confused24.gif)
Beakster |
I haven't had any luck trying to find this button and still haven't been able to open the back trunk .. any other ideas how to get it open ?? (IMG:style_emoticons/default/confused24.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
any other ideas how to get it open ?? (IMG:style_emoticons/default/confused24.gif) There's always the hard way: - Get a friend with a flashlight - Get a ratchet with several extensions, long enough to reach the back of the car from the engine compartment - Open the engine lid - Look for the two white/yellowish plastic cups in the wall between the engine compartment and the trunk - Push them into the trunk - Have your friend shine the flashlight through the passenger hole and onto the lock mechanism in the back - Put a 10mm socket on an extension (use a swivel if you have one) and slide it through the drivers side hole, adding extensions until you can reach the lock - Put the ratchet on the end and undo the two 10mm bolts (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:57 AM |
