> ECU/MPS Compatibility for 2056, D-Jet Experts?
BeatNavy
post Feb 17 2015, 05:26 PM
Getting everything together to install a 2056 into my '72 and swap out the steady, reliable 1.7L I've been running. The 2056 is '73 but came with '74 ECU/MPS combo. The part numbers are 049 on the MPS and 044 on the ECU. Sometimes I'm not sure if I read that ECU/MPS compatibility table on Anders D-Jet site correctly. Is the 049/044 a winning combination?
Also, I've read here that a 2056 really should run with an adjustable MPS. A couple of months ago I converted my 1.7L MPS to adjustable with the Tangerine kit. Any thoughts on whether I could effectively run my MPS (007) just by adjusting it appropriately, or are there other compatibility issues? Or do I need to make that '74 MPS adjustable?
Thanks for the help.
BeatNavy
post Nov 19 2015, 09:36 AM
Chris - are you selling these now? So a x049 MPS can be set to x043 specs with this, right? I have a leaky x049 I wouldn't mind tearing apart.
I've been fiddling with MPS settings the last couple of nights trying to get a rebuilt 043 set correctly. I use Anders' adjustment method he describes, but I can never seem to get all settings (15 in, 4 in, 0 in) correct...
ChrisFoley
post Nov 19 2015, 09:40 AM
I am Tangerine Racing
QUOTE(BeatNavy @ Nov 19 2015, 11:36 AM) *
I will be within a few days.
BeatNavy   ECU/MPS Compatibility for 2056   Feb 17 2015, 05:26 PM
Jeff Bowlsby   Hey Rob, I'm no DJet expert but I think there ...   Feb 17 2015, 06:21 PM
BeatNavy   Hi Jeff -- thanks for the reply. Now I see where ...   Feb 17 2015, 06:35 PM
Bleyseng   As long as: You have a stock grind cam with your 2...   Feb 17 2015, 06:42 PM
Jeff Bowlsby   The 049 can be adjusted to run with the 2056 no p...   Feb 17 2015, 07:47 PM
914_teener   The 049 can be adjusted to run with the 2056 no ...   Feb 17 2015, 09:35 PM
Bleyseng   The 049 can be adjusted to run with the 2056 no ...   Feb 18 2015, 09:00 AM
Frank S   As long as: You have a stock grind cam with your ...   Feb 16 2016, 04:54 AM
Bleyseng   As long as: You have a stock grind cam with your...   Feb 16 2016, 08:44 AM
Frank S   [quote name='Frank S' post='2303674' date='Feb 16...   Feb 16 2016, 09:39 AM
Bleyseng   [quote name='Frank S' post='2303674' date='Feb 1...   Feb 17 2016, 02:45 AM
Frank S   [quote name='Frank S' post='2303719' date='Feb 16...   Feb 17 2016, 09:53 AM
Bleyseng   [quote name='Frank S' post='2303719' date='Feb 1...   Feb 18 2016, 12:26 AM
worn   It's easier to adjust a MPS using a 044 ECU ...   Feb 16 2016, 10:13 AM
BeatNavy   Hi Geoff -- good info, thanks. Cam is stock. Sou...   Feb 17 2015, 06:47 PM
worn   Hi Geoff -- good info, thanks. Cam is stock. So...   Feb 19 2015, 06:25 PM
BeatNavy   So Geoff, would you say my best bet is to either: ...   Feb 18 2015, 09:20 AM
Bleyseng   I have some spacers but you have to take apart the...   Feb 18 2015, 05:52 PM
BeatNavy   I have some spacers but you have to take apart th...   Feb 18 2015, 06:51 PM
Scarlet75   Geoff, Do you have a picture of this spacer? Tha...   Feb 19 2015, 10:52 AM
brant   I'd love to buy a spacer... or if these are al...   Feb 19 2015, 10:56 AM
Phoenix914   :popcorn: Rob, thanks for starting this thread. ...   Feb 19 2015, 11:14 AM
BeatNavy   :popcorn: Rob, thanks for starting this thread....   Feb 19 2015, 01:02 PM
Bleyseng   Pic of inside a early cover showing the cast in st...   Feb 19 2015, 12:06 PM
Scarlet75   Geoff, Other then being cast this way, some MPS ...   Feb 19 2015, 01:44 PM
Racer Chris   I have a spacer in my spare parts collection. Thic...   Feb 19 2015, 01:53 PM
BeatNavy   I have a spacer in my spare parts collection. Thi...   Feb 19 2015, 02:45 PM
Racer Chris   ... Just to be clear though -- I think they...   Feb 19 2015, 04:07 PM
brant   I have a spacer in my spare parts collection. Thi...   Feb 19 2015, 02:49 PM
brant   I'm struggling to visualize this... but I want...   Feb 19 2015, 02:03 PM
Jeff Bowlsby   Chris is the Man for this MPS spacer ring, you alr...   Feb 19 2015, 02:52 PM
914_teener   There also was a rumor that the springs are differ...   Feb 19 2015, 06:30 PM
Bleyseng   Springs are differnet between the early and late o...   Feb 19 2015, 06:44 PM
914_teener   Springs are differnet between the early and late ...   Feb 19 2015, 07:45 PM
Bleyseng   [quote name='Bleyseng' post='2149020' date='Feb 1...   Feb 19 2015, 08:14 PM
914_teener   [quote name='Bleyseng' post='2149020' date='Feb ...   Feb 19 2015, 09:52 PM
worn   [quote name='Bleyseng' post='2149020' date='Feb ...   Feb 22 2015, 06:36 PM
barefoot   There are 2 ways to increase fuel flow, everything...   Feb 19 2015, 07:05 PM
Bob L.   There are 2 ways to increase fuel flow, everythin...   Feb 19 2015, 07:33 PM
barefoot   There are 2 ways to increase fuel flow, everythi...   Feb 19 2015, 07:48 PM
Bleyseng   Pic of the 2.0L spacer ring   Feb 22 2015, 05:35 PM
Racer Chris   Pic of the 2.0L spacer ring Pic of many 2.0L spa...   Nov 19 2015, 09:07 AM
914_teener   [quote name='Bleyseng' post='2150304' date='Feb 2...   Nov 19 2015, 12:48 PM
Racer Chris   [quote name='Bleyseng' post='2150304' date='Feb ...   Nov 19 2015, 03:28 PM
BeatNavy   I put the 049 that came with my 2056 into my 1.7L ...   Feb 22 2015, 06:54 PM
Bleyseng   A 007 will work only if you have a late cover as t...   Feb 22 2015, 08:34 PM
BeatNavy   Chris - are you selling these now? So a x049 MPS ...   Nov 19 2015, 09:36 AM
Racer Chris   Chris - are you selling these now? I will be wit...   Nov 19 2015, 09:40 AM
Olympic 1.7   Chris - are you selling these now? I will be wi...   Nov 19 2015, 07:46 PM
Jeff Bowlsby   Anders published values are known to be lean.   Nov 19 2015, 10:14 AM
BeatNavy   Anders published values are known to be lean. Re...   Nov 19 2015, 10:50 AM
Jeff Bowlsby   We're those values adjusted for your local eva...   Nov 19 2015, 11:25 AM
BeatNavy   Jeff - I did not adjust for sea level, but I'm...   Nov 19 2015, 11:31 AM
pbanders   I haven't got much to add, Bleyseng and Bowlsb...   Nov 19 2015, 01:15 PM
396   I haven't got much to add, Bleyseng and Bowls...   Nov 19 2015, 01:31 PM
Bleyseng   I haven't got much to add, Bleyseng and Bowls...   Feb 16 2016, 08:48 AM
worn   I haven't got much to add, Bleyseng and Bowls...   Feb 16 2016, 10:09 AM
914_teener   This has been a great thread for my 2056 D-jet bui...   Nov 19 2015, 02:30 PM
BeatNavy   This has been a great thread for my 2056 D-jet bu...   Nov 19 2015, 07:15 PM
saigon71   Great info...following this thread closely as I pl...   Nov 19 2015, 07:41 PM
BeatNavy   I spent a lot of time futzing with my MPS's (I...   Feb 16 2016, 10:29 AM
Philip W.   this might be slightly off topic but involves the ...   Feb 17 2016, 08:06 AM
BeatNavy   Those numbers sited on the Anders' site are ta...   Feb 17 2016, 09:08 AM
Philip W.   Those numbers sited on the Anders' site are t...   Feb 17 2016, 09:46 AM
Philip W.   o.k. so as of today I found only one for sale out ...   Feb 17 2016, 09:55 AM
worn   o.k. so as of today I found only one for sale out...   Feb 17 2016, 10:28 AM
BeatNavy   o.k. so as of today I found only one for sale out...   Feb 17 2016, 10:30 AM
sean_v8_914   awesome thread. thank you   Feb 17 2016, 11:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:43 PM
