| TheCabinetmaker |
Nov 22 2015, 06:35 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Went turkey and fixins shopping today. Got home and noticed oil burning smell. Washed and polished the new paint and noticed a puddle of oil underneath. Oil dripping out the flywheel inspection hole. Half a pint maybe. Not a big deal, but it is my daily driver. I have a running 1.8 with dual 34s in a wrecked car. Plan is to remove 1.8, remove carbs, install a freshly painted set of 1.7 tins, plenum, and runners, move my fi items, minus ecu and mps, and install in my car. I'll have three days, and Brian, my right hand. I think we can do it. Won't be able to get started till Friday. Has to be done by next Monday. Can I do it?
Btw, it's a 2056, raby 9550 cam, with 70 plus thousand. It's definitely time for a refresh. |
| TheCabinetmaker |
Nov 22 2015, 07:51 PM
That's the plan Stu. I have nothing else to drive just now. Truck is down too.
Unfortunately, I know what I'm gonna find. The rear main thrust bearing is worn down from the flywheel. I can hear the crank walking. |
| porschetub |
Nov 22 2015, 08:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
That's the plan Stu. I have nothing else to drive just now. Truck is down too. Unfortunately, I know what I'm gonna find. The rear main thrust bearing is worn down from the flywheel. I can hear the crank walking. Bugger that's no good,can you remember what the RMS was ,on Pelican the Victor Reinz seals have been giving grief,I replaced mine for a genuine Porsche one,the VR one didn't fit as well as the genuine replacement ,this is on a -6 just asking.....? |
The Cabinetmaker Blew a rear crank seal today. Nov 22 2015, 06:35 PM
rick 918-S Sux, Just a thought could it be a oil galley plug ... Nov 22 2015, 06:51 PM
The Cabinetmaker Drilled, tapped, and plugged. Nov 22 2015, 06:52 PM
rjames The hardest part is balancing the transmission on ... Nov 22 2015, 07:12 PM
The Cabinetmaker Thanks Robert. I'm an old veteran at removing ... Nov 22 2015, 07:29 PM
stugray There's also the option that you slide off the... Nov 22 2015, 07:44 PM
stugray Oh, and the title reminded me of:
This penguin is... Nov 22 2015, 07:49 PM
Kansas 914
This penguin i... Nov 22 2015, 10:39 PM
hndyhrr
This penguin i... Nov 23 2015, 11:43 AM
The Cabinetmaker Lmao! That's funny stuff stu. Thanks. I ne... Nov 22 2015, 07:59 PM
The Cabinetmaker I've been using the black sabo seals with good... Nov 22 2015, 08:53 PM
r_towle Yes it is possible, I one day if you have the pain... Nov 22 2015, 10:27 PM
euro911 Blew a seal, eh?
zSi-yCV-gQ4
:poke: Nov 23 2015, 12:58 AM
Tom_T Good luck ole buddy & have a good break for so... Nov 23 2015, 11:12 AM
stugray
And Stu, I thought the Penguin was on the telly... Nov 23 2015, 12:20 PM
Jeff Bowlsby If'n it were me, I would just pull the tranny ... Nov 23 2015, 11:55 AM
rjames
If'n it were me, I would just pull the tranny... Nov 23 2015, 02:21 PM
The Cabinetmaker
If'n it were me, I would just pull the trann... Nov 23 2015, 02:28 PM
Eric_Shea http://www.914world.com/bbs2/uploads_offsite/www.r... Nov 23 2015, 01:16 PM
euro911 :( ... <_< Nov 23 2015, 03:39 PM
rgalla9146 Did I miss the part about what engine it is ?
4 ... Nov 23 2015, 09:03 PM
r_towle Why do you think this happened?
Bearing failure? Nov 23 2015, 09:12 PM
colingreene Possible the shim stack might not have been right? Nov 24 2015, 12:36 PM
The Cabinetmaker
Possible the shim stack might not have been right... Nov 24 2015, 01:26 PM
r_towle Did you build the motor? Nov 24 2015, 07:08 PM
The Cabinetmaker
Yes, I did. Nov 24 2015, 07:15 PM
r_towle :chair: :headbang: :poke: :stooges: Nov 24 2015, 08:05 PM
The Cabinetmaker :bootyshake: :splat: :splat: :alfred: :jerk: ... Nov 24 2015, 08:11 PM
r_towle Soooo
Did you get it done? Nov 30 2015, 11:11 PM
The Cabinetmaker Sure rich. I removed the drive train, split the ca... Dec 1 2015, 02:46 AM
r_towle
Sure rich. I removed the drive train, split the c... Dec 3 2015, 07:55 PM
euro911 :lol: Dec 1 2015, 03:41 AM
The Cabinetmaker I already figured out that was what you meant rich... Dec 3 2015, 08:03 PM
Spoke I just went from 1.8L with FI to 2056 with carbs. ... Dec 3 2015, 08:27 PM
r_towle Oh no....put it on Jack stands to give it a proper... Dec 3 2015, 08:28 PM
The Cabinetmaker Up date. I've been driving the old truck while... Feb 9 2016, 07:14 AM
CatDaddy60
Up date. I've been driving the old truck whil... Feb 9 2016, 07:34 AM
Kansas 914
Yesterday was the day! Rolled the engine und... Feb 9 2016, 09:34 AM
rhodyguy Super! But you make the rest of of us slackers... Feb 9 2016, 08:15 AM
brant Awesome Feb 9 2016, 08:38 AM
The Cabinetmaker I spent 4 hrs setting the end play this time. Then... Feb 9 2016, 12:42 PM
914werke Perhaps I missed the detail of the issue.
Was the... Feb 9 2016, 01:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 01:32 AM |
