> Blew a rear crank seal today.
TheCabinetmaker
post Nov 22 2015, 06:35 PM
I drive my car everyday
Went turkey and fixins shopping today. Got home and noticed oil burning smell. Washed and polished the new paint and noticed a puddle of oil underneath. Oil dripping out the flywheel inspection hole. Half a pint maybe. Not a big deal, but it is my daily driver. I have a running 1.8 with dual 34s in a wrecked car. Plan is to remove 1.8, remove carbs, install a freshly painted set of 1.7 tins, plenum, and runners, move my fi items, minus ecu and mps, and install in my car. I'll have three days, and Brian, my right hand. I think we can do it. Won't be able to get started till Friday. Has to be done by next Monday. Can I do it?
Btw, it's a 2056, raby 9550 cam, with 70 plus thousand. It's definitely time for a refresh.
colingreene
post Nov 24 2015, 12:36 PM
Possible the shim stack might not have been right?
TheCabinetmaker
post Nov 24 2015, 01:26 PM
QUOTE(colingreene @ Nov 24 2015, 01:36 PM) *
That is the possibility I'm suspecting most.
The Cabinetmaker   Blew a rear crank seal today.   Nov 22 2015, 06:35 PM
rick 918-S   Sux, Just a thought could it be a oil galley plug ...   Nov 22 2015, 06:51 PM
The Cabinetmaker   Drilled, tapped, and plugged.   Nov 22 2015, 06:52 PM
rjames   The hardest part is balancing the transmission on ...   Nov 22 2015, 07:12 PM
The Cabinetmaker   Thanks Robert. I'm an old veteran at removing ...   Nov 22 2015, 07:29 PM
stugray   There's also the option that you slide off the...   Nov 22 2015, 07:44 PM
stugray   Oh, and the title reminded me of: This penguin is...   Nov 22 2015, 07:49 PM
Kansas 914   Oh, and the title reminded me of: This penguin i...   Nov 22 2015, 10:39 PM
hndyhrr   Oh, and the title reminded me of: This penguin i...   Nov 23 2015, 11:43 AM
The Cabinetmaker   That's the plan Stu. I have nothing else to dr...   Nov 22 2015, 07:51 PM
porschetub   That's the plan Stu. I have nothing else to d...   Nov 22 2015, 08:16 PM
The Cabinetmaker   Lmao! That's funny stuff stu. Thanks. I ne...   Nov 22 2015, 07:59 PM
The Cabinetmaker   I've been using the black sabo seals with good...   Nov 22 2015, 08:53 PM
r_towle   Yes it is possible, I one day if you have the pain...   Nov 22 2015, 10:27 PM
euro911   Blew a seal, eh? zSi-yCV-gQ4 :poke:   Nov 23 2015, 12:58 AM
Tom_T   Good luck ole buddy & have a good break for so...   Nov 23 2015, 11:12 AM
stugray   And Stu, I thought the Penguin was on the telly...   Nov 23 2015, 12:20 PM
Jeff Bowlsby   If'n it were me, I would just pull the tranny ...   Nov 23 2015, 11:55 AM
rjames   If'n it were me, I would just pull the tranny...   Nov 23 2015, 02:21 PM
The Cabinetmaker   If'n it were me, I would just pull the trann...   Nov 23 2015, 02:28 PM
Eric_Shea   http://www.914world.com/bbs2/uploads_offsite/www.r...   Nov 23 2015, 01:16 PM
euro911   :( ... <_<   Nov 23 2015, 03:39 PM
rgalla9146   Did I miss the part about what engine it is ? 4 ...   Nov 23 2015, 09:03 PM
r_towle   Why do you think this happened? Bearing failure?   Nov 23 2015, 09:12 PM
colingreene   Possible the shim stack might not have been right?   Nov 24 2015, 12:36 PM
The Cabinetmaker   Possible the shim stack might not have been right...   Nov 24 2015, 01:26 PM
r_towle   Did you build the motor?   Nov 24 2015, 07:08 PM
The Cabinetmaker   Did you build the motor? Yes, I did.   Nov 24 2015, 07:15 PM
r_towle   :chair: :headbang: :poke: :stooges:   Nov 24 2015, 08:05 PM
The Cabinetmaker   :bootyshake: :splat: :splat: :alfred: :jerk: ...   Nov 24 2015, 08:11 PM
r_towle   Soooo Did you get it done?   Nov 30 2015, 11:11 PM
The Cabinetmaker   Sure rich. I removed the drive train, split the ca...   Dec 1 2015, 02:46 AM
r_towle   Sure rich. I removed the drive train, split the c...   Dec 3 2015, 07:55 PM
euro911   :lol:   Dec 1 2015, 03:41 AM
The Cabinetmaker   I already figured out that was what you meant rich...   Dec 3 2015, 08:03 PM
Spoke   I just went from 1.8L with FI to 2056 with carbs. ...   Dec 3 2015, 08:27 PM
r_towle   Oh no....put it on Jack stands to give it a proper...   Dec 3 2015, 08:28 PM
The Cabinetmaker   Up date. I've been driving the old truck while...   Feb 9 2016, 07:14 AM
CatDaddy60   Up date. I've been driving the old truck whil...   Feb 9 2016, 07:34 AM
Kansas 914   Yesterday was the day! Rolled the engine und...   Feb 9 2016, 09:34 AM
rhodyguy   Super! But you make the rest of of us slackers...   Feb 9 2016, 08:15 AM
brant   Awesome   Feb 9 2016, 08:38 AM
The Cabinetmaker   I spent 4 hrs setting the end play this time. Then...   Feb 9 2016, 12:42 PM
914werke   Perhaps I missed the detail of the issue. Was the...   Feb 9 2016, 01:23 PM
- Lo-Fi Version Time is now: 15th March 2026 - 01:35 AM
