| jimkelly |
Nov 27 2015, 01:31 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I have a renegade radiator in my v8 car and it is leaking. I bought the radiator from renegade probably around 2005, not much miles on it, but lots of years.
any suggestions on who I can buy a replacement radiator from? and cost? model number would be great. Attached image(s)
| Cracker |
Nov 28 2015, 08:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
Jim - I attached a little message on your thread earlier in the alignment post - don't know if you saw it. Anyhow, why don't you consider a steel radiator? I highly doubt weight is important with your application and they are used in OEM ALL the time. I'm using a steel unit and I have a problem OVER cooling. Just another option (that is stronger) and less leak prone. All the best.
Tony |
| jimkelly |
Nov 28 2015, 08:55 AM
I did miss that post. someone mentioned copper core. for $140, i think i'll give aluminum one more try. but will keep steel in mind. thanks (IMG:style_emoticons/default/beerchug.gif)
Jim - I attached a little message on your thread earlier in the alignment post - don't know if you saw it. Anyhow, why don't you consider a steel radiator? I highly doubt weight is important with your application and they are used in OEM ALL the time. I'm using a steel unit and I have a problem OVER cooling. Just another option (that is stronger) and less leak prone. All the best. Tony |
jimkelly are aluminum radiators generally repairable? Nov 27 2015, 01:31 PM
GeorgeRud If a local radiator shop can't help you, I ima... Nov 27 2015, 02:10 PM
veekry9 http://www.griffinrad.com/company.php?tid=33
A cu... Nov 27 2015, 02:17 PM
jimkelly I just emailed griffin. dtf.
http://www.griffinr... Nov 27 2015, 02:53 PM
colingreene Depends on where the leak is coming from
Saldana R... Nov 27 2015, 02:22 PM
mb911
I have a renegade radiator in my v8 car and it is... Nov 27 2015, 02:49 PM
sb914 So my car had a renegade radiator that had less th... Nov 27 2015, 03:45 PM
Andyrew Where is the leak coming from? Mine started leakin... Nov 27 2015, 03:56 PM
jimkelly looking at radiator from front, but I have a grill... Nov 27 2015, 04:02 PM
Andyrew
looking at radiator from front, but I have a gril... Nov 27 2015, 04:29 PM
jimkelly bars.. huh.. Nov 27 2015, 03:58 PM
jimkelly yeah.. I may have one reasonably close.. I will ca... Nov 27 2015, 04:40 PM
matthepcat I had a similar experience. Maybe try a copper cor... Nov 27 2015, 04:46 PM
Chris914n6 Back in my day Renegade radiators were made by Ron... Nov 27 2015, 05:22 PM
dlkawashima
Back in my day Renegade radiators were made by Ro... Nov 28 2015, 01:47 PM
jimkelly removed shroud cover. seems leak is clearly far m... Nov 27 2015, 06:36 PM
matthepcat Believe me it's not worth repairing. It will l... Nov 27 2015, 07:51 PM
Andyrew Thats the radiator I have and Mike Bellis has. He... Nov 27 2015, 07:59 PM
jimkelly celica radiator threads and a pic from each
http:... Nov 27 2015, 08:25 PM
Andyrew Yup. You can see that I mounted mine really close ... Nov 27 2015, 08:33 PM
jimkelly just ordered to splices from jags that run, a 1 to... Nov 27 2015, 08:55 PM
Cairo94507 That just does not make sense. Aluminum radiators... Nov 28 2015, 08:08 AM
rmdinmd I have never known bars leak to work for any perio... Nov 28 2015, 08:12 AM
crash914 be sure to use the correct coolant for aluminum. ... Nov 28 2015, 09:46 AM
jimkelly few more pics of the shrouding. Nov 28 2015, 10:12 AM
jimkelly I bought this one today. thanks. Nov 28 2015, 02:55 PM
ThePaintedMan Chads74 has a Renegrade radiator too, and he's... Nov 28 2015, 03:10 PM
Chris H. Dang that Celica radiator is really becoming the s... Nov 28 2015, 04:40 PM
Mike Bellis
Dang that Celica radiator is really becoming the ... Nov 28 2015, 08:17 PM
jimkelly ray (aka: A&P Mech) provided me these addition... Nov 29 2015, 08:14 AM
dakotaewing
ray (aka: A&P Mech) provided me these additio... Nov 29 2015, 08:10 PM
A&P Mech Jim, you are correct. The top and bottom isolation... Nov 29 2015, 10:21 AM
76-914 Jim, once your radiator is installed and topped of... Nov 29 2015, 10:56 AM
jimkelly i'm thinking you are serious? just never hear... Nov 29 2015, 12:34 PM
76-914 Absotootely. The reason I wanted to see the voltag... Nov 29 2015, 12:51 PM
A&P Mech
[quote name='jimkelly' post='2270986' date='Nov 2... Nov 29 2015, 09:02 PM
dakotaewing Thanks Ray! What were you using for the upper... Nov 29 2015, 10:07 PM
A&P Mech You are correct. I made aluminum mount and found a... Nov 29 2015, 10:22 PM
chads74 This is some great info. Like George said I have h... Nov 30 2015, 12:05 AM
jimkelly seems ray welded tabs at the far ends of the lower... Nov 30 2015, 07:21 AM
A&P Mech
seems ray welded tabs at the far ends of the lowe... Nov 30 2015, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:20 AM |
