> are aluminum radiators generally repairable?, my renegade radiator is leaking : (
jimkelly
post Nov 27 2015, 01:31 PM
Delaware USA
I have a renegade radiator in my v8 car and it is leaking. I bought the radiator from renegade probably around 2005, not much miles on it, but lots of years.
any suggestions on who I can buy a replacement radiator from? and cost? model number would be great.
A&P Mech
post Nov 29 2015, 10:21 AM
Jim, you are correct. The top and bottom isolation mount posts are different sizes. The post for the lower mount is larger than the top. All the pictures of the radiator that I found show the radiator sitting up side down from the way the that the Toyota OEM lower vibration mounts would dictate. I mounted mine based on that.
jimkelly   are aluminum radiators generally repairable?   Nov 27 2015, 01:31 PM
GeorgeRud   If a local radiator shop can't help you, I ima...   Nov 27 2015, 02:10 PM
veekry9   http://www.griffinrad.com/company.php?tid=33 A cu...   Nov 27 2015, 02:17 PM
jimkelly   I just emailed griffin. dtf. http://www.griffinr...   Nov 27 2015, 02:53 PM
colingreene   Depends on where the leak is coming from Saldana R...   Nov 27 2015, 02:22 PM
mb911   I have a renegade radiator in my v8 car and it is...   Nov 27 2015, 02:49 PM
sb914   So my car had a renegade radiator that had less th...   Nov 27 2015, 03:45 PM
Andyrew   Where is the leak coming from? Mine started leakin...   Nov 27 2015, 03:56 PM
jimkelly   looking at radiator from front, but I have a grill...   Nov 27 2015, 04:02 PM
Andyrew   looking at radiator from front, but I have a gril...   Nov 27 2015, 04:29 PM
jimkelly   bars.. huh..   Nov 27 2015, 03:58 PM
jimkelly   yeah.. I may have one reasonably close.. I will ca...   Nov 27 2015, 04:40 PM
matthepcat   I had a similar experience. Maybe try a copper cor...   Nov 27 2015, 04:46 PM
Chris914n6   Back in my day Renegade radiators were made by Ron...   Nov 27 2015, 05:22 PM
dlkawashima   Back in my day Renegade radiators were made by Ro...   Nov 28 2015, 01:47 PM
jimkelly   removed shroud cover. seems leak is clearly far m...   Nov 27 2015, 06:36 PM
matthepcat   Believe me it's not worth repairing. It will l...   Nov 27 2015, 07:51 PM
Andyrew   Thats the radiator I have and Mike Bellis has. He...   Nov 27 2015, 07:59 PM
jimkelly   celica radiator threads and a pic from each http:...   Nov 27 2015, 08:25 PM
Andyrew   Yup. You can see that I mounted mine really close ...   Nov 27 2015, 08:33 PM
jimkelly   just ordered to splices from jags that run, a 1 to...   Nov 27 2015, 08:55 PM
Cairo94507   That just does not make sense. Aluminum radiators...   Nov 28 2015, 08:08 AM
rmdinmd   I have never known bars leak to work for any perio...   Nov 28 2015, 08:12 AM
Cracker   Jim - I attached a little message on your thread e...   Nov 28 2015, 08:51 AM
jimkelly   I did miss that post. someone mentioned copper co...   Nov 28 2015, 08:55 AM
crash914   be sure to use the correct coolant for aluminum. ...   Nov 28 2015, 09:46 AM
jimkelly   few more pics of the shrouding.   Nov 28 2015, 10:12 AM
jimkelly   I bought this one today. thanks.   Nov 28 2015, 02:55 PM
ThePaintedMan   Chads74 has a Renegrade radiator too, and he's...   Nov 28 2015, 03:10 PM
Chris H.   Dang that Celica radiator is really becoming the s...   Nov 28 2015, 04:40 PM
Mike Bellis   Dang that Celica radiator is really becoming the ...   Nov 28 2015, 08:17 PM
jimkelly   ray (aka: A&P Mech) provided me these addition...   Nov 29 2015, 08:14 AM
dakotaewing   ray (aka: A&P Mech) provided me these additio...   Nov 29 2015, 08:10 PM
A&P Mech   Jim, you are correct. The top and bottom isolation...   Nov 29 2015, 10:21 AM
76-914   Jim, once your radiator is installed and topped of...   Nov 29 2015, 10:56 AM
jimkelly   i'm thinking you are serious? just never hear...   Nov 29 2015, 12:34 PM
76-914   Absotootely. The reason I wanted to see the voltag...   Nov 29 2015, 12:51 PM
A&P Mech   [quote name='jimkelly' post='2270986' date='Nov 2...   Nov 29 2015, 09:02 PM
dakotaewing   Thanks Ray! What were you using for the upper...   Nov 29 2015, 10:07 PM
A&P Mech   You are correct. I made aluminum mount and found a...   Nov 29 2015, 10:22 PM
chads74   This is some great info. Like George said I have h...   Nov 30 2015, 12:05 AM
jimkelly   seems ray welded tabs at the far ends of the lower...   Nov 30 2015, 07:21 AM
A&P Mech   seems ray welded tabs at the far ends of the lowe...   Nov 30 2015, 01:48 PM
- Lo-Fi Version Time is now: 12th August 2026 - 04:21 AM
