| jimkelly |
Nov 27 2015, 01:31 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I have a renegade radiator in my v8 car and it is leaking. I bought the radiator from renegade probably around 2005, not much miles on it, but lots of years.
any suggestions on who I can buy a replacement radiator from? and cost? model number would be great. Attached image(s)
| A&P Mech |
Nov 30 2015, 01:48 PM
Member ![]() ![]() Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
seems ray welded tabs at the far ends of the lower mount as to stay away from the sheet metal work zone but i assume the lower mount can be attached to car anywhere along that bottom section of frame. those tabs must be a semi bitch to get bolts thru? I placed the tabs in that location to avoid drilling through the floor. The thought was to keep the attachment hardware inside and out of the elements. It was probably over thinking it a bit but It really worked out great. The bolts are pretty easy to get in and out and the mount is very solid when bolted in. It almost feels like it is welded in place. |
jimkelly are aluminum radiators generally repairable? Nov 27 2015, 01:31 PM
GeorgeRud If a local radiator shop can't help you, I ima... Nov 27 2015, 02:10 PM
veekry9 http://www.griffinrad.com/company.php?tid=33
A cu... Nov 27 2015, 02:17 PM
jimkelly I just emailed griffin. dtf.
http://www.griffinr... Nov 27 2015, 02:53 PM
colingreene Depends on where the leak is coming from
Saldana R... Nov 27 2015, 02:22 PM
mb911
I have a renegade radiator in my v8 car and it is... Nov 27 2015, 02:49 PM
sb914 So my car had a renegade radiator that had less th... Nov 27 2015, 03:45 PM
Andyrew Where is the leak coming from? Mine started leakin... Nov 27 2015, 03:56 PM
jimkelly looking at radiator from front, but I have a grill... Nov 27 2015, 04:02 PM
Andyrew
looking at radiator from front, but I have a gril... Nov 27 2015, 04:29 PM
jimkelly bars.. huh.. Nov 27 2015, 03:58 PM
jimkelly yeah.. I may have one reasonably close.. I will ca... Nov 27 2015, 04:40 PM
matthepcat I had a similar experience. Maybe try a copper cor... Nov 27 2015, 04:46 PM
Chris914n6 Back in my day Renegade radiators were made by Ron... Nov 27 2015, 05:22 PM
dlkawashima
Back in my day Renegade radiators were made by Ro... Nov 28 2015, 01:47 PM
jimkelly removed shroud cover. seems leak is clearly far m... Nov 27 2015, 06:36 PM
matthepcat Believe me it's not worth repairing. It will l... Nov 27 2015, 07:51 PM
Andyrew Thats the radiator I have and Mike Bellis has. He... Nov 27 2015, 07:59 PM
jimkelly celica radiator threads and a pic from each
http:... Nov 27 2015, 08:25 PM
Andyrew Yup. You can see that I mounted mine really close ... Nov 27 2015, 08:33 PM
jimkelly just ordered to splices from jags that run, a 1 to... Nov 27 2015, 08:55 PM
Cairo94507 That just does not make sense. Aluminum radiators... Nov 28 2015, 08:08 AM
rmdinmd I have never known bars leak to work for any perio... Nov 28 2015, 08:12 AM
Cracker Jim - I attached a little message on your thread e... Nov 28 2015, 08:51 AM
jimkelly I did miss that post. someone mentioned copper co... Nov 28 2015, 08:55 AM
crash914 be sure to use the correct coolant for aluminum. ... Nov 28 2015, 09:46 AM
jimkelly few more pics of the shrouding. Nov 28 2015, 10:12 AM
jimkelly I bought this one today. thanks. Nov 28 2015, 02:55 PM
ThePaintedMan Chads74 has a Renegrade radiator too, and he's... Nov 28 2015, 03:10 PM
Chris H. Dang that Celica radiator is really becoming the s... Nov 28 2015, 04:40 PM
Mike Bellis
Dang that Celica radiator is really becoming the ... Nov 28 2015, 08:17 PM
jimkelly ray (aka: A&P Mech) provided me these addition... Nov 29 2015, 08:14 AM
dakotaewing
ray (aka: A&P Mech) provided me these additio... Nov 29 2015, 08:10 PM
A&P Mech Jim, you are correct. The top and bottom isolation... Nov 29 2015, 10:21 AM
76-914 Jim, once your radiator is installed and topped of... Nov 29 2015, 10:56 AM
jimkelly i'm thinking you are serious? just never hear... Nov 29 2015, 12:34 PM
76-914 Absotootely. The reason I wanted to see the voltag... Nov 29 2015, 12:51 PM
A&P Mech
[quote name='jimkelly' post='2270986' date='Nov 2... Nov 29 2015, 09:02 PM
dakotaewing Thanks Ray! What were you using for the upper... Nov 29 2015, 10:07 PM
A&P Mech You are correct. I made aluminum mount and found a... Nov 29 2015, 10:22 PM
chads74 This is some great info. Like George said I have h... Nov 30 2015, 12:05 AM
jimkelly seems ray welded tabs at the far ends of the lower... Nov 30 2015, 07:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:22 AM |
