| jack20 |
Nov 30 2015, 05:13 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California
I need to replace the front rubber bushings and am planning to use the Elephant Racing bushings and install tools. I have not been able to find a video or other info regarding removal of the control arms. I am not near my car so I can't crawl under right now.
Will I need to remove the hubs, brakes or anything else to remove the control arms? Thanks, Jack |
| pete000 |
Nov 30 2015, 06:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I did the Elephant rubber bushings and it was not too tough if you have the big clamp tool or equivalent.
The Elephant has how to vids on their site. |
| jack20 |
Nov 30 2015, 06:08 PM
I did the Elephant rubber bushings and it was not too tough if you have the big clamp tool or equivalent. The Elephant has how to vids on their site. I watched the video. What I need to know is how many other components no to be removed in order to remove the control arms. |
jack20 Control Arm Bushing Replacement Nov 30 2015, 05:13 PM
Harpo The only hard part was getting the old bushings of... Nov 30 2015, 06:30 PM
jack20
The only hard part was getting the old bushings o... Nov 30 2015, 06:41 PM
LowBridge This is the minimum needed to replace the bushings... Nov 30 2015, 06:49 PM
jack20
This is the minimum needed to replace the bushing... Nov 30 2015, 06:54 PM
LowBridge
This is the minimum needed to replace the bushin... Dec 1 2015, 05:51 AM
pete000 Burning the rubber bushing is messy.
They do jus... Nov 30 2015, 07:11 PM
stugray I have done this twice recently, once at the track... Nov 30 2015, 07:12 PM
jack20
I have done this twice recently, once at the trac... Nov 30 2015, 07:19 PM
stugray After purchasing the elephants, I found these for ... Nov 30 2015, 09:05 PM
JamesM
After purchasing the elephants, I found these for... Dec 1 2015, 12:45 AM
Java2570 If you are going with the rubber bushings, absolut... Dec 1 2015, 09:20 AM
Olympic 1.7
If you are going with the rubber bushings, absolu... Dec 1 2015, 10:49 AM
JamesM
If you are going with the rubber bushings, absol... Dec 1 2015, 04:48 PM
Catorse Easy! 20 ton press takes the bushings with the... Dec 1 2015, 08:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 02:44 PM |
