| Shindog1961 |
Nov 29 2015, 11:42 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
Anyone use Patrick Motorsports in Phoenix for their 914?
| brp986s |
Nov 30 2015, 01:15 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Their shift linkage kit for WEVO 915 is junk, and high-priced. Atleast when I bought it 5 yrs ago. Their clutch cable set up for same is/was half-baked. You can't adjust it in-situ and the tension on the cable makes installation difficult. And the cable sleeve connection at the firewall is the same diameter as the stub. Duh. And they never returned my core refund for the needed custom 915 shift rod. Called, called, called - gave up. Their spherical bearing for the shift rod at the firewall has no boot or seal, so it is exposed to dirt and water ingress - again half-baked. Probably best to think of their kits as starting points than turn-key solutions, except they are priced as solutions.
| Steve |
Nov 30 2015, 06:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Their shift linkage kit for WEVO 915 is junk, and high-priced. Atleast when I bought it 5 yrs ago. Their clutch cable set up for same is/was half-baked. You can't adjust it in-situ and the tension on the cable makes installation difficult. And the cable sleeve connection at the firewall is the same diameter as the stub. Duh. And they never returned my core refund for the needed custom 915 shift rod. Called, called, called - gave up. Their spherical bearing for the shift rod at the firewall has no boot or seal, so it is exposed to dirt and water ingress - again half-baked. Probably best to think of their kits as starting points than turn-key solutions, except they are priced as solutions. I am running the Martin Bott 916 setup. I am using the PMS clutch pulley and cable. No problems. Everything fit perfectly. This was six months ago. He must of fixed it. I am also using the firewall bearing and am worried about the same issue without a boot. My shift linkage is early 914-4 with a CFR adapter, apex joints and 5/8" rod. |
| bcheney |
Nov 30 2015, 09:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
James is a complete gentleman, a true Porsche professional and is passionate about his work and the level of service he provides. I have found him very good to deal with. I was in Phoenix a couple months back and stopped in to see the shops in person. Well organized, clean and professionally run. He is building a new shop that will be around 25,000 sq ft all under one roof. I have confidence recommending them.
Shindog1961 Patrick Motorsports Nov 29 2015, 11:42 PM
SirAndy Bring loads of $$$ ...
:popcorn: Nov 29 2015, 11:51 PM
Shindog1961 Recommendations? No one here wants to work on 914... Nov 30 2015, 12:36 AM
boxsterfan
Recommendations? No one here wants to work on 914... Nov 30 2015, 02:12 PM
MJHanna What kind of "work" are you looking to g... Nov 30 2015, 07:07 AM
Coondog My 914 is in there shop right now and I live in Ca... Nov 30 2015, 07:33 AM
Cairo94507 They are a terrific shop and know these cars insid... Nov 30 2015, 08:21 AM
396 PMS, great place and quality of work is equivalent... Nov 30 2015, 09:26 AM
Cracker I have bought many "parts" from PM - Jam... Nov 30 2015, 09:48 AM
Steve Ditto to the above. I used to live in Chandler AZ... Nov 30 2015, 09:58 AM
SKL1 They are also building a new shop/building. I thi... Nov 30 2015, 10:08 AM
Krieger Ive been very happy with the many parts I have bou... Nov 30 2015, 10:24 AM
whitetwinturbo :beer3: Drink this:
[url=http://www.patrickmo... Nov 30 2015, 11:02 AM
396
:beer3: Drink this:
[url=http://www.patrickm... Nov 30 2015, 11:42 AM
RobW Met them at RRV. Seemed like good P-car folks.... Nov 30 2015, 01:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:56 PM |
