Ebrake handle ratchet issue |
dangerranger01 |
Dec 2 2015, 06:26 PM
Member Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
So I've had an issue where the ebrake handle ractchet doesn't always catch. Today i was pulling carpet to inspect my longs and had to pull the handle so thought i would look into it.
First, is the pivot supposed to be slightly bent toward the rear? (IMG:http://www.914world.com/bbs2/uploads_offsite/i718.photobucket.com-4578-1449102381.1.jpg) ^^That might be my issue. You see the pawl will tweak to the inside and looks to miss the teeth. I think the bend in the pivot would cause this... Anybody experience this before and have a fix? Maybe i could bend the pivot?. Any help is appreciated. (IMG:http://www.914world.com/bbs2/uploads_offsite/i718.photobucket.com-4578-1449102381.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i718.photobucket.com-4578-1449102381.3.jpg) |
rgalla9146 |
Dec 2 2015, 09:47 PM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Remove the handle and use a vise or a vise grip to squeeze the sides closer together with the toothed part removed. Leave only enough space for the ratchet to move freely.
By doing this the ratchet teeth will stay in better alignment. While it is out put the toothy ratchet part in the vise and use a V shape file to renew the shape of the teeth. Lubricate the moving parts and reassemble. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:51 AM |
