> 1971 part identification
mikesjunk
post Dec 6 2015, 06:38 PM
EDITED to put smaller pictures below.
Ok, so my sister has a 1971 Porsche 914 that somehow I've been asked to get running again. It's had a few too many people under the hood over the years so there's quite a list of projects to do.
So first question is there a good manual that would be recommended for these so I might not have to ask question like will be below. Haynes, Chilton, ??
One of the first project is new fuel line front to back as they are pretty rotted. Next project is to verify the wiring as there's been a lot of playing around with the double relay.
Since I'm doing fuel lines the tank is out. Under the tank was a vacuum type line that didn't seem to have a home. Any suggestions where this was supposed to go. Come through the floor loops around and ends up by steering shaft.
Next question is what are the correct names two sensors? They are part of the double relay wiring and I'm tracing wires. Blue one, Brown one.
And then for now on this thread. What is this?
mikesjunk   1971 part identification   Dec 6 2015, 06:38 PM
bandjoey   Like to help but pictures are so large and blurry?...   Dec 6 2015, 07:02 PM
gms   looks like the brake fluid reservoir over flow lin...   Dec 6 2015, 07:25 PM
gms   found a picture   Dec 6 2015, 07:38 PM
mikesjunk   Not sure why the pics are so large. I even compre...   Dec 6 2015, 08:10 PM
PanelBilly   Use the post preview to see how your photos will l...   Dec 6 2015, 08:22 PM
mikesjunk   OK not sure why they wouldn't come across smal...   Dec 6 2015, 08:35 PM
McMark   First picture is a late AAR, usually found on L-Je...   Dec 7 2015, 08:30 AM
Dave_Darling   Haynes for the manual. It's not very good, bu...   Dec 7 2015, 10:26 AM
mikesjunk   Thanks for the replies this will help. Any othe...   Dec 7 2015, 09:19 PM
Dave_Darling   Double relay means it's using L-jetronic injec...   Dec 7 2015, 10:36 PM
mikesjunk   Ok so confirmed loose line in front should go to b...   Dec 9 2015, 04:49 PM
Dave_Darling   W is the code for an early 1.7 engine. It could b...   Dec 9 2015, 05:40 PM
ClayPerrine   From the look of the plenum and throttle body, I ...   Dec 9 2015, 05:56 PM
mikesjunk   Great replies and thanks. Any leads I can get to ...   Dec 9 2015, 06:57 PM
Dave_Darling   Wow, Clay--you could see the photos before he post...   Dec 10 2015, 12:54 AM
mikesjunk   Great thought on recording the part numbers. Sinc...   Dec 10 2015, 01:00 PM
Dave_Darling   The 71 would be D-jet. D-jet runs its pump off a ...   Dec 10 2015, 02:14 PM
- Lo-Fi Version Time is now: 4th July 2025 - 01:48 PM
