| iwanta914-6 |
Dec 10 2015, 09:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None
I know it's not a 914 but one of my girls (I have twin 7 year old girls in girl scouts) wanted a "Sally" from Cars.
So obviously I was excited to get started on that as Sally is based off of a 996, so to CAD I went. This is only the second year I've "helped" my girls with their cars so this is my first attempt at adding flares to a pinewood car. Should be fun. Next year they will do most of the work and I'll just help make it fast but this year I'll handle most of the construction while they do the paint. The other car is going to be a puppy. I had to modify it a little to fit the size limits and the minimum wheelbase being 4" pushed the rear wheels back a little. ![]() |
| dflesburg |
Dec 10 2015, 11:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Both my boys were in for years (we even did guides before cub scouts) my youngest son who is turning 18 next week is an eagle scout....
I was a den leader for many years and cubmaster for some, then a scout leader for a few more. After a while, here is what I learned. 1. tape off the axle area then let the boys make any car they want. It doesn't matter 2. help them cut it and carve it and let them paint it. It doesn't matter 3. balance it and make it weigh 5.000 or 4.9999 4. make it roll across the floor straight and fast. 5. let them race it. let them play with it after the racing is over, let them have fun. We won a lot but hopefully what is more important is they had fun. |
| PlantMan |
Dec 10 2015, 05:20 PM
Member ![]() ![]() Group: Members Posts: 458 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Both my boys were in for years (we even did guides before cub scouts) my youngest son who is turning 18 next week is an eagle scout.... I was a den leader for many years and cubmaster for some, then a scout leader for a few more. After a while, here is what I learned. 1. tape off the axle area then let the boys make any car they want. It doesn't matter 2. help them cut it and carve it and let them paint it. It doesn't matter 3. balance it and make it weigh 5.000 or 4.9999 4. make it roll across the floor straight and fast. 5. let them race it. let them play with it after the racing is over, let them have fun. We won a lot but hopefully what is more important is they had fun. Good advise here. I have built many cars in the last ten plus years. My oldest in a Life Scout and finishing up his Eagle requirements. My middle son is heading to Boy Scouts next month and my youngest is a Bear. Also have a daughter who is the twin to my older son and she is in American Heritage Girls. If you can get your car to run on three wheels in a straight line that is the key. Don't forget to make room for your weights prior to cutting your body. You will need a significant amount of weight so plan accordingly. Make sure you read-up on tract clearance under the wheels and overhead. The car usually has to stay within it's wheel base. Polish your axles on a drill or drill press. use dry graphite on the axles after you get your car built, it will make a BIG difference. You can get extra supplies at Michaels/Hobby Lobby, etc. I ran the Pine Wood Derby for several years....it was often more exciting for the Dads than the lads/girls but was always fun either way! Have a great time! |
| jasons |
Dec 11 2015, 08:18 AM
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
If you can get your car to run on three wheels in a straight line that is the key. We tuned our car to rail ride, not straight. It works. Don't forget to make room for your weights prior to cutting your body. Get the tungsten weights, they are more dense than anything else and make placement much easier and tune-able. Buy them at Hobby Lobby with the 40% coupon from their website. |
iwanta914-6 Pinewood Derby Season Dec 10 2015, 09:37 AM
Mueller Looks good....I hope you leave off the tramp stamp... Dec 10 2015, 09:40 AM
iwanta914-6
Looks good....I hope you leave off the tramp stam... Dec 10 2015, 09:46 AM
jasons We are building a car too. Last year we won the B... Dec 10 2015, 11:01 AM
iwanta914-6 Last year the two cars I made with my girls (I had... Dec 10 2015, 11:43 AM
iwanta914-6
1. tape off the axle area then let the boys make ... Dec 10 2015, 01:46 PM
jor This should be a build post -- I'd love to see... Dec 10 2015, 04:26 PM
Garland When you think it's at max weight, add staples... Dec 10 2015, 05:56 PM
The Cabinetmaker Here's one I helped my grandson with last year... Dec 10 2015, 06:11 PM
74ravenna
Here's one I helped my grandson with last yea... Dec 10 2015, 06:21 PM
PlantMan
Here's one I helped my grandson with last yea... Dec 10 2015, 06:48 PM
The Cabinetmaker
Here's one I helped my grandson with last ye... Dec 11 2015, 05:46 AM
brant My brother in law made this for my niece and then ... Dec 10 2015, 08:12 PM
wes Our boys first year, he won two 1st place trophys... Dec 11 2015, 11:13 AM
wes video of one of the races. Dec 11 2015, 11:21 AM
wes not bad for his first year! Dec 11 2015, 11:25 AM
Spoke Built a few cars for a friend's son before. I ... Dec 11 2015, 11:37 AM
r_towle Sand wheels true and sand the nails for the axles.... Dec 11 2015, 12:38 PM
Spoke
Sand wheels true and sand the nails for the axles... Dec 11 2015, 03:44 PM
cgnj
[quote name='r_towle' post='2276038' date='Dec 11... Dec 12 2015, 06:18 PM
RobW All good advice!
We are in year 3. Buddy took... Dec 11 2015, 03:34 PM
RobW
All good advice!
We are in year 3. Buddy too... Dec 13 2015, 08:45 PM
iwanta914-6 Progress...
Dec 13 2015, 04:30 PM
r_towle Sliding internal weight inside a tube Dec 13 2015, 04:42 PM
jmalone We built several cool cars, the "Cheese Wedge... Dec 13 2015, 06:38 PM
iwanta914-6 Shaping pretty much complete. Just needs a little... Dec 17 2015, 02:21 PM
jasons Looks Great! 1.8 OZ, that sounds like a lot.... Dec 17 2015, 03:38 PM
iwanta914-6
Looks Great! 1.8 OZ, that sounds like a lot... Dec 17 2015, 05:04 PM
7TPorsh That looks great! Shave the bottom down until... Dec 17 2015, 04:51 PM
wes Drill holes from underneath in the front area unti... Dec 17 2015, 08:32 PM
iwanta914-6
Drill holes from underneath in the front area unt... Dec 18 2015, 08:36 AM
iwanta914-6 After doing some calculations, it's going to b... Dec 18 2015, 11:17 AM
jasons Yeah, what I know is this.... I watched a bunch of... Dec 18 2015, 01:25 PM
iwanta914-6
Yeah, what I know is this.... I watched a bunch o... Dec 18 2015, 01:46 PM
Amphicar770 This is starting to sound like the movie "Dow... Dec 18 2015, 01:43 PM
veekry9 http://www.westsystem.com/ss/building-a-gr...mula-... Dec 18 2015, 04:16 PM
7TPorsh Use a drill pres with the car on its side and cut ... Dec 18 2015, 04:54 PM
jmill Looking good. My son was a big Dale Jr. fan. I h... Dec 18 2015, 05:47 PM
jmill Bottom Dec 18 2015, 05:48 PM
db9146 Micro polish the nails (shaft and back of nail hea... Dec 18 2015, 10:59 PM
iwanta914-6
Micro polish the nails (shaft and back of nail he... Dec 19 2015, 05:00 PM
iwanta914-6 So I'm just about done. It's not perfect,... Jan 12 2016, 03:59 PM
RobW Wow! Nice work! Jan 12 2016, 05:32 PM
dflesburg Here is one, I made back in the day around 1998 (n... Jan 13 2016, 07:46 AM
RobW We don't have our cars yet but this year will ... Jan 13 2016, 09:35 AM
jasons We did a wedge last year. I'm sure flatter/si... Jan 13 2016, 10:11 AM
mbseto Flat/wedge seems to be a winning style, but as lon... Jan 13 2016, 01:36 PM
dflesburg shape is unimportant.... see my previous posts... ... Jan 13 2016, 02:24 PM
iwanta914-6
shape is unimportant.... see my previous posts...... Jan 14 2016, 08:00 AM
RobW Here's last year.... Jan 14 2016, 08:23 AM
RobW This is in the finals. The car in lane one took fi... Jan 14 2016, 08:46 AM
RobW Here's the release gate. Thinking about a high... Jan 14 2016, 08:49 AM
RobW Does rolling it on a treadmill help as well? Jan 14 2016, 09:06 AM
RobW Buddy won tonight! :cheer: :cheer: :cheer: ... Feb 20 2016, 12:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:59 PM |
