> 914-6 oil tank fittings
mb911
post Dec 9 2015, 10:20 AM
Guys,
I need to have some fittings machined and wanted to know what the factory 914-6 oil tank fittings are suppose to be?
jmill
post Dec 13 2015, 04:23 PM
Green Hornet
I looked into it a while ago. Links for the tank prints are here:
http://www.914world.com/bbs2/index.php?sho...756&hl=tank
mb911   914-6 oil tank fittings   Dec 9 2015, 10:20 AM
screenguy914   The cost to create fittings from scratch might be ...   Dec 9 2015, 10:41 AM
mb911   The cost to create fittings from scratch might be...   Dec 9 2015, 10:56 AM
porschetub   The cost to create fittings from scratch might b...   Dec 9 2015, 12:55 PM
mb911   I will probably offer them both ways.. Just want t...   Dec 9 2015, 04:41 PM
jfort   I have AN   Dec 9 2015, 04:45 PM
rgalla9146   The attached image has non- original fittings to t...   Dec 9 2015, 07:54 PM
Mark Henry   Personally if the tank is not correct then use mor...   Dec 12 2015, 12:18 AM
porschetub   Personally if the tank is not correct then use mo...   Dec 12 2015, 02:53 AM
rgalla9146   Personally if the tank is not correct then use m...   Dec 12 2015, 05:08 PM
Mark Henry   [quote name='porschetub' post='2276220' date='Dec...   Dec 12 2015, 08:20 PM
Mikey914   You may want to take a part an original, as they a...   Dec 13 2015, 02:40 PM
mepstein   Ben - I can't offer to have you take apart my ...   Dec 13 2015, 02:57 PM
Mark Henry   I can show you a 72 911 tank that was cut open. T...   Dec 13 2015, 04:13 PM
rgalla9146   I can show you a 72 911 tank that was cut open. ...   Dec 13 2015, 05:32 PM
Mark Henry   [quote name='Mark Henry' post='2276785' date='Dec...   Dec 13 2015, 08:39 PM
jmill   I looked into it a while ago. Links for the tank ...   Dec 13 2015, 04:23 PM
mb911   I looked into it a while ago. Links for the tank...   Dec 13 2015, 06:53 PM
worn   [quote name='jmill' post='2276788' date='Dec 13 2...   Jan 27 2016, 12:44 PM
mb911   Wow didn't check for a couple days and now all...   Dec 13 2015, 06:05 PM
jmill   [quote name='jmill' post='2276788' date='Dec 13 2...   Dec 14 2015, 09:53 AM
Eric_Shea   You Cheeseheads get together over a couple-a brats...   Dec 14 2015, 11:58 AM
mb911   I actually work at the local tech college as a wel...   Dec 14 2015, 02:39 PM
jmill   I'm in the market for an aluminum tank without...   Dec 14 2015, 05:05 PM
mb911   I'm in the market for an aluminum tank withou...   Dec 14 2015, 05:17 PM
mb911   here is a rough template. I will test fit over the...   Dec 15 2015, 11:03 AM
jmill   Looking good. If you're going to mass produce...   Dec 15 2015, 04:38 PM
mb911   Looking good. If you're going to mass produc...   Dec 15 2015, 07:11 PM
mb911   Looking good. If you're going to mass produ...   Dec 16 2015, 06:22 AM
mb911   Looking good. If you're going to mass produ...   Dec 16 2015, 10:46 AM
mb911   Ok another question for all of you. The oil line ...   Dec 16 2015, 06:22 PM
mb911   Here is the first revision to the plug/template an...   Dec 17 2015, 10:42 AM
mb911   and a comparison. may still need to revise more bu...   Dec 17 2015, 11:51 AM
mb911   Ok another update. The revision fits in perfect.. ...   Dec 17 2015, 02:30 PM
396   Ok another update. The revision fits in perfect.....   Dec 17 2015, 07:10 PM
mb911   Ok another update. The revision fits in perfect....   Dec 17 2015, 07:18 PM
brant   tank looks good I made the same one about 5 years...   Dec 17 2015, 03:10 PM
mb911   It's ok I needed to do it from scratch for a s...   Dec 17 2015, 03:15 PM
brant   I kept the internal baffling and internal screen b...   Dec 17 2015, 03:58 PM
Eric_Shea   A drain cock would be much appreciated. Excellent...   Dec 17 2015, 04:23 PM
mb911   A drain cock would be much appreciated. Excellen...   Dec 17 2015, 05:04 PM
Eric_Shea   I can send you one. This is what I was thinking. ...   Dec 17 2015, 06:02 PM
mb911   I can send you one. This is what I was thinking....   Dec 17 2015, 06:32 PM
brant   pictures of the one I made about 8 years back.. a...   Dec 17 2015, 07:21 PM
brant   and   Dec 17 2015, 07:22 PM
brant   last:   Dec 17 2015, 07:23 PM
mb911   It's hard to tell from the picture but is that...   Dec 17 2015, 07:30 PM
brant   It's hard to tell from the picture but is tha...   Dec 17 2015, 07:57 PM
wndsnd   Wow, you guys are some talented mofos. :) I wi...   Dec 17 2015, 08:00 PM
mb911   I am really excited to be back in the game and wil...   Dec 17 2015, 09:56 PM
mb911   Another question for you is of all the tanks out t...   Dec 27 2015, 02:26 PM
Eric_Shea   No issues whatsoever...   Dec 28 2015, 12:14 PM
Mark Henry   Is that screen stainless steel? or what is it mad...   Dec 28 2015, 01:40 PM
mb911   Is that screen stainless steel? or what is it ma...   Dec 28 2015, 01:57 PM
jmill   If you do install a baffle I would recommend a dif...   Dec 28 2015, 01:56 PM
mb911   If you do install a baffle I would recommend a di...   Dec 28 2015, 02:06 PM
sixnotfour   .750 would be an improvement .. and make filter co...   Dec 28 2015, 02:00 PM
mb911   .750 would be an improvement .. and make filter c...   Dec 28 2015, 02:03 PM
jmill   You can add tabs. Cut two slots in the backside a...   Dec 28 2015, 02:22 PM
jmill   Ugly pic but you'll get the idea.   Dec 28 2015, 02:29 PM
Mark Henry   I'm less concerned with the baffle, as long as...   Dec 28 2015, 02:55 PM
mb911   I'm less concerned with the baffle, as long a...   Dec 28 2015, 03:35 PM
mb911   I'm less concerned with the baffle, as long ...   Jan 4 2016, 03:23 PM
mb911   I am ordering fittings today have all of you decid...   Jan 7 2016, 08:49 AM
Mark Henry   I am ordering fittings today have all of you deci...   Jan 7 2016, 09:06 AM
mb911   I am ordering fittings today have all of you dec...   Jan 7 2016, 09:13 AM
jd74914   I like the ideal of female standard fittings a wel...   Jan 7 2016, 11:20 AM
jmill   I can see why PMS went with M22. You can readily ...   Jan 7 2016, 12:45 PM
jmill   You could just leave it at that, as there is metr...   Jan 7 2016, 01:11 PM
mb911   You could just leave it at that, as there is met...   Jan 7 2016, 07:36 PM
jmill   We should just do yours in straight AN way easier...   Jan 7 2016, 08:53 PM
mb911   Ok I have researched it like crazy 22mm is the bes...   Jan 9 2016, 11:54 AM
mb911   So quick update this is the final transfer pattern...   Jan 13 2016, 07:18 PM
mb911   1st one for jmill and remote oil filter set up   Jan 17 2016, 06:06 PM
mb911   I used baffle specd by customer production units w...   Jan 17 2016, 06:09 PM
mb911   Tank ready for -12 weld on bungs   Jan 17 2016, 06:10 PM
mb911   Boy I thought there would be some excitement for t...   Jan 18 2016, 12:40 PM
jmill   Heck, I'm all kinds of excited! :wub: ...   Jan 18 2016, 01:04 PM
mepstein   Powder coat looks nice but chances are it's go...   Jan 18 2016, 01:14 PM
jd74914   That looks nice! I like that the baffles are w...   Jan 18 2016, 01:36 PM
Eric_Shea   Aluminum, like steel or cast iron, needs to be p...   Jan 18 2016, 01:49 PM
mepstein   Aluminum, like steel or cast iron, needs to be ...   Jan 18 2016, 02:26 PM
worn   Aluminum, like steel or cast iron, needs to be...   Jan 27 2016, 01:53 PM
mb911   [quote name='mepstein' post='2291143' date='Jan 1...   Jan 27 2016, 02:21 PM
mb911   All good points.. I did choose 5052 h32 for 2 reas...   Jan 18 2016, 02:53 PM
porschetub   All good points.. I did choose 5052 h32 for 2 rea...   Feb 16 2016, 12:50 AM
MJHanna   Anodizing is not any more cost than powder coating...   Jan 18 2016, 03:02 PM
mb911   Anodizing is not any more cost than powder coatin...   Jan 18 2016, 04:18 PM
BigD9146gt   Good'ay guys... I only skimmed this so please...   Jan 24 2016, 10:55 PM
mb911   Good'ay guys... I only skimmed this so pleas...   Jan 27 2016, 10:47 AM
Mark Henry   I agree and that is the conclusion I came to as w...   Jan 27 2016, 02:40 PM
mb911   I agree and that is the conclusion I came to as ...   Jan 27 2016, 04:45 PM
jmill   Thick powder coat, like what my PC guy does on bl...   Jan 27 2016, 02:48 PM
mb911   Here is number 1 of the oil tanks with oil filter ...   Feb 8 2016, 12:47 PM
jd74914   That looks like it fits really nice!   Feb 8 2016, 01:48 PM
johnhora   :agree: Very nice!   Feb 8 2016, 02:03 PM
mb911   Thanks.. I appreciate the support.. Going to revis...   Feb 8 2016, 02:53 PM
mb911   Took off a half day today to finish up some tanks ...   Feb 15 2016, 03:56 PM
restore2seater   Since you're shipping them, does that mean you...   Feb 15 2016, 10:46 PM
Steve   Looking forward to the heat exchangers!!   Feb 16 2016, 12:55 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:21 PM
