> 914-6 oil tank fittings
mb911
post Dec 9 2015, 10:20 AM
Guys,
I need to have some fittings machined and wanted to know what the factory 914-6 oil tank fittings are suppose to be?
Mark Henry
post Dec 13 2015, 04:13 PM
that's what I do!
I can show you a 72 911 tank that was cut open.
There is a bit to them, but they are just a can with a bit of internal plumbing and baffles. The oil enters the tank and is then plumbed through the oil filter, back into the tank and out onto the top of the screen baffle. The main baffle is just a SS screen, which is about 1/3 of the way down from the top of the tank. The oil exits towards the rear of the tank bottom. You could make a simple can and use an external oil filter mount, but you must keep the tank screen/baffle as that is what separates the air from the oil.
There is nothing high pressure about the tank, the highest pressure would be the restriction of the oil filter.
I looked into doing this myself, it would be a fair bit of work to get it right but it is doable.
If you were to fab a tank, mild steel would be fine as long as the tank is sealed and always filled with clean oil. The issue would be rust through from the outside, the top being the most prone.
If you are good at welding and don't mind a bit of extra weight I bet you could MIG weld a steel tank. SS or AL would be better, but then you need a TIG welder.
In the end I found a deal on a complete DWD tank set and I scooped it up.
rgalla9146
post Dec 13 2015, 05:32 PM
QUOTE(Mark Henry @ Dec 13 2015, 05:13 PM) *
A mild steel tank will rust out from the inside too.
This is especially so with cars that sit for long periods.
The water condensate pools on the bottom of the tank as well as in droplets on the upper inside.
This is probably why the factory copper plated the tanks.
mb911   914-6 oil tank fittings   Dec 9 2015, 10:20 AM
screenguy914   The cost to create fittings from scratch might be ...   Dec 9 2015, 10:41 AM
mb911   The cost to create fittings from scratch might be...   Dec 9 2015, 10:56 AM
porschetub   The cost to create fittings from scratch might b...   Dec 9 2015, 12:55 PM
mb911   I will probably offer them both ways.. Just want t...   Dec 9 2015, 04:41 PM
jfort   I have AN   Dec 9 2015, 04:45 PM
rgalla9146   The attached image has non- original fittings to t...   Dec 9 2015, 07:54 PM
Mark Henry   Personally if the tank is not correct then use mor...   Dec 12 2015, 12:18 AM
porschetub   Personally if the tank is not correct then use mo...   Dec 12 2015, 02:53 AM
rgalla9146   Personally if the tank is not correct then use m...   Dec 12 2015, 05:08 PM
Mark Henry   [quote name='porschetub' post='2276220' date='Dec...   Dec 12 2015, 08:20 PM
Mikey914   You may want to take a part an original, as they a...   Dec 13 2015, 02:40 PM
mepstein   Ben - I can't offer to have you take apart my ...   Dec 13 2015, 02:57 PM
Mark Henry   I can show you a 72 911 tank that was cut open. T...   Dec 13 2015, 04:13 PM
rgalla9146   I can show you a 72 911 tank that was cut open. ...   Dec 13 2015, 05:32 PM
Mark Henry   [quote name='Mark Henry' post='2276785' date='Dec...   Dec 13 2015, 08:39 PM
jmill   I looked into it a while ago. Links for the tank ...   Dec 13 2015, 04:23 PM
mb911   I looked into it a while ago. Links for the tank...   Dec 13 2015, 06:53 PM
worn   [quote name='jmill' post='2276788' date='Dec 13 2...   Jan 27 2016, 12:44 PM
mb911   Wow didn't check for a couple days and now all...   Dec 13 2015, 06:05 PM
jmill   [quote name='jmill' post='2276788' date='Dec 13 2...   Dec 14 2015, 09:53 AM
Eric_Shea   You Cheeseheads get together over a couple-a brats...   Dec 14 2015, 11:58 AM
mb911   I actually work at the local tech college as a wel...   Dec 14 2015, 02:39 PM
jmill   I'm in the market for an aluminum tank without...   Dec 14 2015, 05:05 PM
mb911   I'm in the market for an aluminum tank withou...   Dec 14 2015, 05:17 PM
mb911   here is a rough template. I will test fit over the...   Dec 15 2015, 11:03 AM
jmill   Looking good. If you're going to mass produce...   Dec 15 2015, 04:38 PM
mb911   Looking good. If you're going to mass produc...   Dec 15 2015, 07:11 PM
mb911   Looking good. If you're going to mass produ...   Dec 16 2015, 06:22 AM
mb911   Looking good. If you're going to mass produ...   Dec 16 2015, 10:46 AM
mb911   Ok another question for all of you. The oil line ...   Dec 16 2015, 06:22 PM
mb911   Here is the first revision to the plug/template an...   Dec 17 2015, 10:42 AM
mb911   and a comparison. may still need to revise more bu...   Dec 17 2015, 11:51 AM
mb911   Ok another update. The revision fits in perfect.. ...   Dec 17 2015, 02:30 PM
396   Ok another update. The revision fits in perfect.....   Dec 17 2015, 07:10 PM
mb911   Ok another update. The revision fits in perfect....   Dec 17 2015, 07:18 PM
brant   tank looks good I made the same one about 5 years...   Dec 17 2015, 03:10 PM
mb911   It's ok I needed to do it from scratch for a s...   Dec 17 2015, 03:15 PM
brant   I kept the internal baffling and internal screen b...   Dec 17 2015, 03:58 PM
Eric_Shea   A drain cock would be much appreciated. Excellent...   Dec 17 2015, 04:23 PM
mb911   A drain cock would be much appreciated. Excellen...   Dec 17 2015, 05:04 PM
Eric_Shea   I can send you one. This is what I was thinking. ...   Dec 17 2015, 06:02 PM
mb911   I can send you one. This is what I was thinking....   Dec 17 2015, 06:32 PM
brant   pictures of the one I made about 8 years back.. a...   Dec 17 2015, 07:21 PM
brant   and   Dec 17 2015, 07:22 PM
brant   last:   Dec 17 2015, 07:23 PM
mb911   It's hard to tell from the picture but is that...   Dec 17 2015, 07:30 PM
brant   It's hard to tell from the picture but is tha...   Dec 17 2015, 07:57 PM
wndsnd   Wow, you guys are some talented mofos. :) I wi...   Dec 17 2015, 08:00 PM
mb911   I am really excited to be back in the game and wil...   Dec 17 2015, 09:56 PM
mb911   Another question for you is of all the tanks out t...   Dec 27 2015, 02:26 PM
Eric_Shea   No issues whatsoever...   Dec 28 2015, 12:14 PM
Mark Henry   Is that screen stainless steel? or what is it mad...   Dec 28 2015, 01:40 PM
mb911   Is that screen stainless steel? or what is it ma...   Dec 28 2015, 01:57 PM
jmill   If you do install a baffle I would recommend a dif...   Dec 28 2015, 01:56 PM
mb911   If you do install a baffle I would recommend a di...   Dec 28 2015, 02:06 PM
sixnotfour   .750 would be an improvement .. and make filter co...   Dec 28 2015, 02:00 PM
mb911   .750 would be an improvement .. and make filter c...   Dec 28 2015, 02:03 PM
jmill   You can add tabs. Cut two slots in the backside a...   Dec 28 2015, 02:22 PM
jmill   Ugly pic but you'll get the idea.   Dec 28 2015, 02:29 PM
Mark Henry   I'm less concerned with the baffle, as long as...   Dec 28 2015, 02:55 PM
mb911   I'm less concerned with the baffle, as long a...   Dec 28 2015, 03:35 PM
mb911   I'm less concerned with the baffle, as long ...   Jan 4 2016, 03:23 PM
mb911   I am ordering fittings today have all of you decid...   Jan 7 2016, 08:49 AM
Mark Henry   I am ordering fittings today have all of you deci...   Jan 7 2016, 09:06 AM
mb911   I am ordering fittings today have all of you dec...   Jan 7 2016, 09:13 AM
jd74914   I like the ideal of female standard fittings a wel...   Jan 7 2016, 11:20 AM
jmill   I can see why PMS went with M22. You can readily ...   Jan 7 2016, 12:45 PM
jmill   You could just leave it at that, as there is metr...   Jan 7 2016, 01:11 PM
mb911   You could just leave it at that, as there is met...   Jan 7 2016, 07:36 PM
jmill   We should just do yours in straight AN way easier...   Jan 7 2016, 08:53 PM
mb911   Ok I have researched it like crazy 22mm is the bes...   Jan 9 2016, 11:54 AM
mb911   So quick update this is the final transfer pattern...   Jan 13 2016, 07:18 PM
mb911   1st one for jmill and remote oil filter set up   Jan 17 2016, 06:06 PM
mb911   I used baffle specd by customer production units w...   Jan 17 2016, 06:09 PM
mb911   Tank ready for -12 weld on bungs   Jan 17 2016, 06:10 PM
mb911   Boy I thought there would be some excitement for t...   Jan 18 2016, 12:40 PM
jmill   Heck, I'm all kinds of excited! :wub: ...   Jan 18 2016, 01:04 PM
mepstein   Powder coat looks nice but chances are it's go...   Jan 18 2016, 01:14 PM
jd74914   That looks nice! I like that the baffles are w...   Jan 18 2016, 01:36 PM
Eric_Shea   Aluminum, like steel or cast iron, needs to be p...   Jan 18 2016, 01:49 PM
mepstein   Aluminum, like steel or cast iron, needs to be ...   Jan 18 2016, 02:26 PM
worn   Aluminum, like steel or cast iron, needs to be...   Jan 27 2016, 01:53 PM
mb911   [quote name='mepstein' post='2291143' date='Jan 1...   Jan 27 2016, 02:21 PM
mb911   All good points.. I did choose 5052 h32 for 2 reas...   Jan 18 2016, 02:53 PM
porschetub   All good points.. I did choose 5052 h32 for 2 rea...   Feb 16 2016, 12:50 AM
MJHanna   Anodizing is not any more cost than powder coating...   Jan 18 2016, 03:02 PM
mb911   Anodizing is not any more cost than powder coatin...   Jan 18 2016, 04:18 PM
BigD9146gt   Good'ay guys... I only skimmed this so please...   Jan 24 2016, 10:55 PM
mb911   Good'ay guys... I only skimmed this so pleas...   Jan 27 2016, 10:47 AM
Mark Henry   I agree and that is the conclusion I came to as w...   Jan 27 2016, 02:40 PM
mb911   I agree and that is the conclusion I came to as ...   Jan 27 2016, 04:45 PM
jmill   Thick powder coat, like what my PC guy does on bl...   Jan 27 2016, 02:48 PM
mb911   Here is number 1 of the oil tanks with oil filter ...   Feb 8 2016, 12:47 PM
jd74914   That looks like it fits really nice!   Feb 8 2016, 01:48 PM
johnhora   :agree: Very nice!   Feb 8 2016, 02:03 PM
mb911   Thanks.. I appreciate the support.. Going to revis...   Feb 8 2016, 02:53 PM
mb911   Took off a half day today to finish up some tanks ...   Feb 15 2016, 03:56 PM
restore2seater   Since you're shipping them, does that mean you...   Feb 15 2016, 10:46 PM
Steve   Looking forward to the heat exchangers!!   Feb 16 2016, 12:55 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:43 PM
