| era vulgaris |
Dec 13 2015, 08:49 AM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 986 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
I've developed a leak at the oil pressure sender. However, I have a dual sender and a hose that goes from the sender to the location where the stock oil pressure switch screws into the case.
I'm guessing I need to get a new hose. Where do I get one of these with the correct threads for the sender switch location? I'm also going to replace my oil cooler seals while I'm at it. Is there any difference between brands of oil cooler seals? One better than another? |
| cary |
Dec 13 2015, 10:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
http://type4store.com/products/gaskets-seals.html?p=2
http://www.pelicanparts.com/catalog/SuperC..._pg5.htm#item19 I'm pretty sure I bought mine from PP. But I like the detail at Type 4 stating that there are two thicknesses. |
| era vulgaris |
Dec 13 2015, 11:07 AM
http://type4store.com/products/gaskets-seals.html?p=2 http://www.pelicanparts.com/catalog/SuperC..._pg5.htm#item19 I'm pretty sure I bought mine from PP. But I like the detail at Type 4 stating that there are two thicknesses. I was only curious as far as quality, but now I'm confused. When I did these on my old car, both were the same thickness. Is the T4 store indicating that you're supposed to use one of each thickness? Anyone with the Tangerine Remote Oil Cooler Takeoff kit want to chime in as to which they used? Also I'm surprised 914rubber doesn't make these. Unless I missed them, but I looked through the entire site. |
| ejm |
Dec 13 2015, 06:18 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,716 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
When I did these on my old car, both were the same thickness. Is the T4 store indicating that you're supposed to use one of each thickness? For some VW applications there are thick and thin seals depending on the case/cooler/upright adapter. Upper/lower most likely refers to something there. T4's use two of the thin seals. Pelicans choice is aftermarket or Genuine Porsche, same size, much different price. I've seen grease gun hose failures enough times to never use one again. They collapse internally, completely restricting flow and indicate no pressure when there is and pressure when there isn't. Grease gun and paintball hoses were never intended to take the heat seen in engine compartments. |
era vulgaris oil pressure sender hose Dec 13 2015, 08:49 AM
76-914 Off of a grease gun. Dec 13 2015, 08:54 AM
era vulgaris For real? No mods to it, just plug and play? Dec 13 2015, 08:56 AM
BeatNavy I used AA's "kit": http://www.autoa... Dec 13 2015, 09:00 AM
era vulgaris
I used AA's "kit": http://www.auto... Dec 13 2015, 09:08 AM
cary Rubber Grease Gun Hose.
Hanging on a hook a NAPA. Dec 13 2015, 09:47 AM
era vulgaris Awesome, I'll pick one up today. Thanks guys... Dec 13 2015, 09:49 AM
stugray
I was only curious as far as quality, but now I... Dec 13 2015, 01:49 PM
era vulgaris
I don't want to restart that argument, but t... Dec 13 2015, 07:22 PM
era vulgaris
When I did these on my old car, both were the sam... Dec 13 2015, 07:21 PM
Bleyseng I went to a Brake/Hydraulic hose Shop that makes a... Dec 13 2015, 06:23 PM
era vulgaris
I went to a Brake/Hydraulic hose Shop that makes ... Dec 13 2015, 07:52 PM
brant Ordered that fitting.
Thanks Stu! Dec 13 2015, 07:44 PM
Mark Henry One thing when using a rubber hose is don't fo... Dec 13 2015, 09:04 PM
GregAmy Chris Foley/Tangerine Racing sells a remote-mount ... Dec 13 2015, 09:21 PM
era vulgaris
Chris Foley/Tangerine Racing sells a remote-mount... Dec 14 2015, 08:10 AM
Racer Chris
Where is it on Tangerine's site? Maybe I... Dec 14 2015, 08:48 AM
stugray
Where is it on Tangerine's site? Maybe I... Dec 14 2015, 09:01 AM
Racer Chris
[quote name='Racer Chris' post='2276983' date='De... Dec 14 2015, 02:31 PM
bdstone914 1982 928 rear caliper flex line. Bought one at O... Dec 14 2015, 06:46 AM
era vulgaris
1982 928 rear caliper flex line. Bought one at ... Dec 14 2015, 08:18 AM
blackmoon I bought one for my sender at a local hotrod shop,... Dec 14 2015, 11:20 AM
era vulgaris I just ordered a 928 rear brake line. We'll s... Dec 14 2015, 11:55 AM
BeatNavy That's part of the reason I went and sprung fo... Dec 14 2015, 11:59 AM
RohJay I use this, from a British vendor "LMA Perfor... Dec 14 2015, 12:31 PM
Al Meredith You can use a Paint Ball gun braided hose. Dec 14 2015, 12:46 PM
Brett W What am I missing here, its a 10x1.0 BSP thread on... Dec 14 2015, 01:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:30 AM |
