| mb911 |
Dec 9 2015, 10:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Guys,
I need to have some fittings machined and wanted to know what the factory 914-6 oil tank fittings are suppose to be? |
| Eric_Shea |
Dec 17 2015, 06:02 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I can send you one.
This is what I was thinking. I have one in my F250 and it's priceless: (IMG:http://www.914world.com/bbs2/uploads_offsite/ecx.images-amazon.com-1110-1450396933.1.jpg) |
| mb911 |
Dec 17 2015, 06:32 PM
I can send you one. This is what I was thinking. I have one in my F250 and it's priceless: (IMG:http://www.914world.com/bbs2/uploads_offsite/ecx.images-amazon.com-1110-1450396933.1.jpg) That would be perfect.. Where do you feel would be the best location for it. I would think as close to the oil fees line as possible as that is the lowest point but that would almost require removal of the rocker every time you change the oil |
mb911 914-6 oil tank fittings Dec 9 2015, 10:20 AM
screenguy914 The cost to create fittings from scratch might be ... Dec 9 2015, 10:41 AM
mb911
The cost to create fittings from scratch might be... Dec 9 2015, 10:56 AM
porschetub
The cost to create fittings from scratch might b... Dec 9 2015, 12:55 PM
mb911 I will probably offer them both ways.. Just want t... Dec 9 2015, 04:41 PM
jfort I have AN Dec 9 2015, 04:45 PM
rgalla9146 The attached image has non- original fittings to t... Dec 9 2015, 07:54 PM
Mark Henry Personally if the tank is not correct then use mor... Dec 12 2015, 12:18 AM
porschetub
Personally if the tank is not correct then use mo... Dec 12 2015, 02:53 AM
rgalla9146
Personally if the tank is not correct then use m... Dec 12 2015, 05:08 PM
Mark Henry
[quote name='porschetub' post='2276220' date='Dec... Dec 12 2015, 08:20 PM
Mikey914 You may want to take a part an original, as they a... Dec 13 2015, 02:40 PM
mepstein Ben - I can't offer to have you take apart my ... Dec 13 2015, 02:57 PM
Mark Henry I can show you a 72 911 tank that was cut open.
T... Dec 13 2015, 04:13 PM
rgalla9146
... Dec 13 2015, 05:32 PM
Mark Henry
[quote name='Mark Henry' post='2276785' date='Dec... Dec 13 2015, 08:39 PM
jmill I looked into it a while ago. Links for the tank ... Dec 13 2015, 04:23 PM
mb911
I looked into it a while ago. Links for the tank... Dec 13 2015, 06:53 PM
worn
[quote name='jmill' post='2276788' date='Dec 13 2... Jan 27 2016, 12:44 PM
mb911 Wow didn't check for a couple days and now all... Dec 13 2015, 06:05 PM
jmill
[quote name='jmill' post='2276788' date='Dec 13 2... Dec 14 2015, 09:53 AM
Eric_Shea You Cheeseheads get together over a couple-a brats... Dec 14 2015, 11:58 AM
mb911 I actually work at the local tech college as a wel... Dec 14 2015, 02:39 PM
jmill I'm in the market for an aluminum tank without... Dec 14 2015, 05:05 PM
mb911
I'm in the market for an aluminum tank withou... Dec 14 2015, 05:17 PM
mb911 here is a rough template. I will test fit over the... Dec 15 2015, 11:03 AM
jmill Looking good. If you're going to mass produce... Dec 15 2015, 04:38 PM
mb911
Looking good. If you're going to mass produc... Dec 15 2015, 07:11 PM
mb911
Looking good. If you're going to mass produ... Dec 16 2015, 06:22 AM
mb911
Looking good. If you're going to mass produ... Dec 16 2015, 10:46 AM
mb911 Ok another question for all of you. The oil line ... Dec 16 2015, 06:22 PM
mb911 Here is the first revision to the plug/template an... Dec 17 2015, 10:42 AM
mb911 and a comparison. may still need to revise more bu... Dec 17 2015, 11:51 AM
mb911 Ok another update. The revision fits in perfect.. ... Dec 17 2015, 02:30 PM
396
Ok another update. The revision fits in perfect..... Dec 17 2015, 07:10 PM
mb911
Ok another update. The revision fits in perfect.... Dec 17 2015, 07:18 PM
brant tank looks good
I made the same one about 5 years... Dec 17 2015, 03:10 PM
mb911 It's ok I needed to do it from scratch for a s... Dec 17 2015, 03:15 PM
brant I kept the internal baffling and internal screen b... Dec 17 2015, 03:58 PM
Eric_Shea A drain cock would be much appreciated.
Excellent... Dec 17 2015, 04:23 PM
mb911
Excellen... Dec 17 2015, 05:04 PM
brant pictures of the one I made about 8 years back..
a... Dec 17 2015, 07:21 PM
brant and Dec 17 2015, 07:22 PM
brant last: Dec 17 2015, 07:23 PM
mb911 It's hard to tell from the picture but is that... Dec 17 2015, 07:30 PM
brant
It's hard to tell from the picture but is tha... Dec 17 2015, 07:57 PM
wndsnd Wow, you guys are some talented mofos. :)
I wi... Dec 17 2015, 08:00 PM
mb911 I am really excited to be back in the game and wil... Dec 17 2015, 09:56 PM
mb911 Another question for you is of all the tanks out t... Dec 27 2015, 02:26 PM
Eric_Shea No issues whatsoever... Dec 28 2015, 12:14 PM
Mark Henry Is that screen stainless steel? or what is it mad... Dec 28 2015, 01:40 PM
mb911
Is that screen stainless steel? or what is it ma... Dec 28 2015, 01:57 PM
jmill If you do install a baffle I would recommend a dif... Dec 28 2015, 01:56 PM
mb911
If you do install a baffle I would recommend a di... Dec 28 2015, 02:06 PM
sixnotfour .750 would be an improvement .. and make filter co... Dec 28 2015, 02:00 PM
mb911
.750 would be an improvement .. and make filter c... Dec 28 2015, 02:03 PM
jmill You can add tabs. Cut two slots in the backside a... Dec 28 2015, 02:22 PM
jmill Ugly pic but you'll get the idea. Dec 28 2015, 02:29 PM
Mark Henry I'm less concerned with the baffle, as long as... Dec 28 2015, 02:55 PM
mb911
I'm less concerned with the baffle, as long a... Dec 28 2015, 03:35 PM
mb911
I'm less concerned with the baffle, as long ... Jan 4 2016, 03:23 PM
mb911 I am ordering fittings today have all of you decid... Jan 7 2016, 08:49 AM
Mark Henry
I am ordering fittings today have all of you deci... Jan 7 2016, 09:06 AM
mb911
I am ordering fittings today have all of you dec... Jan 7 2016, 09:13 AM
jd74914 I like the ideal of female standard fittings a wel... Jan 7 2016, 11:20 AM
jmill I can see why PMS went with M22. You can readily ... Jan 7 2016, 12:45 PM
jmill
You could just leave it at that, as there is metr... Jan 7 2016, 01:11 PM
mb911
You could just leave it at that, as there is met... Jan 7 2016, 07:36 PM
jmill
We should just do yours in straight AN way easier... Jan 7 2016, 08:53 PM
mb911 Ok I have researched it like crazy 22mm is the bes... Jan 9 2016, 11:54 AM
mb911 So quick update this is the final transfer pattern... Jan 13 2016, 07:18 PM
mb911 1st one for jmill and remote oil filter set up Jan 17 2016, 06:06 PM
mb911 I used baffle specd by customer production units w... Jan 17 2016, 06:09 PM
mb911 Tank ready for -12 weld on bungs Jan 17 2016, 06:10 PM
mb911 Boy I thought there would be some excitement for t... Jan 18 2016, 12:40 PM
jmill Heck, I'm all kinds of excited! :wub:
... Jan 18 2016, 01:04 PM
mepstein Powder coat looks nice but chances are it's go... Jan 18 2016, 01:14 PM
jd74914 That looks nice! I like that the baffles are w... Jan 18 2016, 01:36 PM
Eric_Shea
Aluminum, like steel or cast iron, needs to be p... Jan 18 2016, 01:49 PM
Aluminum, like steel or cast iron, needs to be ... Jan 18 2016, 02:26 PM
worn
Aluminum, like steel or cast iron, needs to be... Jan 27 2016, 01:53 PM
mb911
[quote name='mepstein' post='2291143' date='Jan 1... Jan 27 2016, 02:21 PM
mb911 All good points.. I did choose 5052 h32 for 2 reas... Jan 18 2016, 02:53 PM
porschetub
All good points.. I did choose 5052 h32 for 2 rea... Feb 16 2016, 12:50 AM
MJHanna Anodizing is not any more cost than powder coating... Jan 18 2016, 03:02 PM
mb911
Anodizing is not any more cost than powder coatin... Jan 18 2016, 04:18 PM
BigD9146gt Good'ay guys...
I only skimmed this so please... Jan 24 2016, 10:55 PM
mb911
Good'ay guys...
I only skimmed this so pleas... Jan 27 2016, 10:47 AM
Mark Henry I agree and that is the conclusion I came to as w... Jan 27 2016, 02:40 PM
mb911
I agree and that is the conclusion I came to as ... Jan 27 2016, 04:45 PM
jmill
Thick powder coat, like what my PC guy does on bl... Jan 27 2016, 02:48 PM
mb911 Here is number 1 of the oil tanks with oil filter ... Feb 8 2016, 12:47 PM
jd74914 That looks like it fits really nice! Feb 8 2016, 01:48 PM
johnhora :agree:
Very nice! Feb 8 2016, 02:03 PM
mb911 Thanks.. I appreciate the support.. Going to revis... Feb 8 2016, 02:53 PM
mb911 Took off a half day today to finish up some tanks ... Feb 15 2016, 03:56 PM
restore2seater Since you're shipping them, does that mean you... Feb 15 2016, 10:46 PM
Steve Looking forward to the heat exchangers!! Feb 16 2016, 12:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:21 PM |
