| kupcar |
Dec 16 2015, 10:28 AM
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
My 914-6 conversion probably needs some sort of catch can. The previous owner has the crankcase vented to the oil tank. The vent from the tank simply has a sponge zip tied to the opening. It seems to work ok and I've never had a issue with anything but there has to be a better alternative. Something simple. Do most use a catch can, or can a small mesh filter be used? I cleaned a bit of oil residue off the motor when I was detailing the car. My guess is it came from venting into the engine compartment. Now that it looks pretty, I'd like to keep it that way. Any suggestions? Thanks.
| arkitect |
Dec 19 2015, 12:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Sorry...double post.
Dave |
| mb911 |
Dec 19 2015, 02:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I made one for my last 6 .it was a piece of 2" aluminium tubing with a bottom welded on with a fitting on top for a small k&n filter with a hose fitting on the side.. I attached it to the fan housing opposite of the coil.. It worked great.. I should make a bunch of them Great idea, I'd be in for one. Don't want to spend $100 for a fancy looking one. I've been searching for a cheaper alternative. Dave I will look and see what I have for material.. I could probably make one for $ 50 but not. Sure what filter I would use? |
| arkitect |
Dec 20 2015, 07:33 AM
I made one for my last 6 .it was a piece of 2" aluminium tubing with a bottom welded on with a fitting on top for a small k&n filter with a hose fitting on the side.. I attached it to the fan housing opposite of the coil.. It worked great.. I should make a bunch of them Great idea, I'd be in for one. Don't want to spend $100 for a fancy looking one. I've been searching for a cheaper alternative. Dave I will look and see what I have for material.. I could probably make one for $ 50 but not. Sure what filter I would use? I've seen the filter for sale separately...sell without with the proper threaded hole on top. Then buyer just add the filter. Dave |
kupcar Oil Catch Can Options Dec 16 2015, 10:28 AM
SirAndy I used an old Gatorade bottle with a few holes dri... Dec 16 2015, 12:26 PM
stugray At the track I am often amazed how many can put th... Dec 16 2015, 01:13 PM
Andyrew This is the one I am going to use.
Gonna fill it... Dec 16 2015, 01:17 PM
falcor75
Gonna fill i... Dec 27 2015, 08:14 AM
Andyrew
[quote name='Andyrew' post='2277838' date='Dec 16... Dec 27 2015, 12:57 PM
boxsterfan What's the part# on that gatorade bottle? :D Dec 16 2015, 01:20 PM
SirAndy What's the part# on that gatorade bottle? :D... Dec 16 2015, 01:40 PM
Jeffs9146 Mine
:blink: :beer2: Dec 16 2015, 04:58 PM
kupcar A+ for creativity across the board. Has anyone eve... Dec 16 2015, 05:18 PM
SirAndy Has anyone ever puked up enough oil to catch anyth... Dec 16 2015, 05:44 PM
Jeffs9146
A+ for creativity across the board. Has anyone ev... Dec 16 2015, 06:15 PM
porschetub
A+ for creativity across the board. Has anyone ev... Dec 16 2015, 08:31 PM
r_towle :) Andy is a redneck......hahahaha
Not something I... Dec 16 2015, 05:22 PM
SirAndy :) Andy is a redneck......hahahaha
Not something I... Dec 16 2015, 05:45 PM
patssle Running Gatorade here too. Andy was my inspiration... Dec 16 2015, 06:08 PM
mb911 I made one for my last 6 .it was a piece of 2... Dec 16 2015, 06:26 PM
The Cabinetmaker I had a carbed 4 for a while that used a small air... Dec 16 2015, 06:45 PM
porschetub
I had a carbed 4 for a while that used a small ai... Dec 16 2015, 10:01 PM
11tenths If only the factory had put one under the battery ... Dec 16 2015, 08:01 PM
Downunderman I vented the catch tank on my 6 back into the bott... Dec 17 2015, 12:42 AM
stugray here's mine for a 4:
http://www.914world.com/... Dec 17 2015, 12:44 AM
JmuRiz I plan on plugging mine into one of these:
http://... Dec 17 2015, 09:39 AM
porschetub
http:/... Dec 17 2015, 01:09 PM
brant mine: Dec 17 2015, 03:12 PM
Maltese Falcon I've had no luck with the K+N on our 2.0 type ... Dec 17 2015, 10:00 PM
Steve Pratel I've got one like this, looks and works great
... Dec 19 2015, 12:10 PM
arkitect
I made one for my last 6 .it was a piece of 2... Dec 19 2015, 12:42 PM
Andyrew Seriously guys this one is made of aluminum and wa... Dec 19 2015, 06:08 PM
jmill
Seriously guys this one is made of aluminum and w... Dec 19 2015, 06:37 PM
jmill Decent read if you're in the market for a catc... Dec 27 2015, 10:33 AM
skier2.0 The small tube on the factory air filter housing g... Jan 1 2016, 09:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:23 PM |
