Alternator - to rebuild or not to rebuild |
iankarr |
Dec 18 2015, 07:53 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
While my motor is out and getting cleaned up, I'm wondering if I should have the alternator rebuilt. Power was fine before the teardown, but given how much of a PITA it is to change the alternator with the motor in the car, do you think it's a good "might as well" to rebuild it now? Buy a new one? |
TheCabinetmaker |
Dec 20 2015, 09:15 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
914 alternators are very robust. I've only seen three fail in the last 40 years. Use your old one, and get a new cooling boot. About 12 bucks at Bughaus.
porschetub |
Dec 20 2015, 06:24 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
914 alternators are very robust. I've only seen three fail in the last 40 years. Use your old one, and get a new cooling boot. About 12 bucks at Bughaus. Very true ,bosch altenators are very well made,only replaced bearings in one of mine cause they had gone dry,spun fine but wanted it to last. DIY is very easy and while you are there you can polish the commutator and give the whole thing a good clean with brake/ electrical cleaner. IMO on a four or six its not an easy job with engine in best to do it @ point of overhaul or engine out. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:21 PM |
