head light reinstall |
80cap |
Jan 3 2016, 09:46 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I just reinstalled my head light assemblies. I have not yet installed the wiring.
How do you sync the system one I wire up the motors. I can't find a thread on this subject. Thanks Brian |
toolguy |
Jan 3 2016, 01:51 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
This is a very abbreviated description of the steps and process. .
If you disturbed the headlight pivot's mounting allens, it's a lot more difficult. . You'll need to align each door to be parallel and perpendicular to the hood and fender and eyebrow. . This is done by rotating the headlight pivot shafts. Not oly are you adjusting the gaps , but you're setting the height to match the hood level. First, remove the headlight motor actuator relay by the motor. . this is so you don't mash fingers. . Also be aware there is an full open door stop adjustment which keeps the headlights from wiggling when open and driving. . it's the big long bolt at the rear of the headlight bucket with the set nut. this is the last thing to adjust. Before you reassemble the door, inspect the top stop bolt and how it braces the headlight base when fully raised. This way you'll understand the very last adjustment, the door stop bolt. Disconnect the raise lower arm from the motor / 10mm nut on bevel shaft. gently pry the arm loose on the serrated bevel so the door will go up and down manually. with the arm lose, adjust the headlight door with the inner and outer pivot mounts so the door is properly aligned. It can be a bitch to get perfect. All this does is align the door. Tighten the pivot allens when gaps are set. Next is to get the full open and full closed position in place. If you haven't rotated the black knob on the rear of the motor, the motor is still in the 'full down position. Connect the actuator arm back on the motor shaft in the furthermost down position. . The door will probably be too high or too low. . Now the height is adjusted by loosening the 3 motor mount allens and repositioning the motor. Now the full down position is set. If the arm is not in the fully down position, this is why some headlights start the up cycle by actually going down a little then up. . Next to the full up position and the door stop bolt adjustment. With the relay still removed, rotate the black knob on the motor until the door is raising itself to full up. . you need to feel as the door rises to contact the stop bolt. You want to adjust the bolt in or out so the door mount assemble barely contacts the bolt in the fully raise position. . too tight and it binds the headlight motor operation. . too lose and the headlights will wiggle and vibrate when driving. . Don't be surprised if it takes all day to do both sides if you want it perfect. . |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:23 AM |
