Electrical problem help please |
Wyvern |
Jan 3 2016, 08:31 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Hello "Brain trust"
Thinking this is an Ignition Switch Issue (but not like I have experienced before) I really did search here and in the www. In a nutshell 73 1.7 ... runs starts and runs fine. When I put the key in and turn to "ON" I have a dead dash. No radio, blinker, or even the Gen light that used to come one . I crank and the engine fires up just fine. But a dead dash and accessories as above including no tach. (no gen light on) As soon as I hit the gas or turn something on (blinkers / headlights) the dash then operates as it should . but gen light now on. 12.6 battery voltage and 14.2 when running . Headlight and hazzards work always (maybe they get power from a more direct source) I could see the switch being bad and not getting power to the dash . but why when I rev or turn something on would it then "make all work ?" interesting and I keep second guessing the alt / and voltage reg are are fault ... but voltage seems good ... believe that is due to what ever issue I have. It is dim at idle and gas . with blink switch on the blinkers dont work and the Gen light become brighter / blinks when the blinkers should be on. any thoughts ? |
Wyvern |
Jan 4 2016, 04:38 PM
Thank you Thank you .
You helped me "see the trees not just the forest" It is hard not to be focused on an effected part and not the cause. Everything is as it should be (IMG:style_emoticons/default/piratenanner.gif) I wish I knew what actually "fixed it" but here is what I did. worked on it last night and most of today . Removed all fuses and relays cleaned contact points (small wire brush on my dremmel or wet / dry sand paper . Cleaned each fuse (replaced a couple) Check physical contacts at fuse spade connections Found a ground location diagram and addressed ALL . Headlights, fuse area, relay area , engine / trans / body ... I think I got them all. Gotta say ... I think it actually runs better ! |
Lo-Fi Version | Time is now: 11th June 2024 - 09:45 PM |
