Interior Restoration Question |
orbit398 |
Jan 6 2016, 08:31 AM
Member Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
On a few padded interior pieces, the black padded vinyl items, I have some small splits/cracks and wonder how these can be repaired to look good.
I was thinking of filling in the cracks with black paintable silicon and then painting the whole piece with black rubberized bumper paint but wondered if others had a better idea. thanks for suggestions |
Mikey914 |
Jan 6 2016, 12:07 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Followed by the upper section.
Once removed you will need to harvest the metal from the old piece. This is most easily done using an small sharp knife to cut the stitches. Each side has one. Once removed, you will need to thread into the new section. Make sure the loop on the metal is at the top by the headrest, so you will feed the un looped section through from the top. This takes a little patience, and when you get to the corner you will need to be gentle as the path is more restricted and more difficult to find. With a little probing you will be able to get it through. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 04:36 PM |
