orbit398
Jan 6 2016, 08:31 AM
On a few padded interior pieces, the black padded vinyl items, I have some small splits/cracks and wonder how these can be repaired to look good.
I was thinking of filling in the cracks with black paintable silicon and then painting the whole piece with black rubberized bumper paint but wondered if others had a better idea.
thanks for suggestions
Dion
Jan 6 2016, 08:44 AM
I've had some success with this kit. Just repaired a center console with it. Just take your time and be patient.
Link:
http://www.eastwood.com/vinyl-and-dashboar...CFYEmHwodyiEHcg
I'd be interested in hearing if there's a way to repair the vinyl also. I noticed a small 1/4" tear in the vinyl around my interior dome light while cleaning. Hopefully this can be fixed before it gets worse.
Mikey914
Jan 6 2016, 11:50 AM
For the foam, silicon would be fine. The vinyl is stretched tight enough that you can't really repair it for any length of time (splits). You may be able to repair a puncture. But this is why I made the back bolster piece available for $69, and I have a few in stock now.
It's actually the easiest piece to do.
Mikey914
Jan 6 2016, 11:58 AM
Here's the article I did for Fourteener motoring
Seat Recovery part I of II
914 seats are one of the most neglected parts of our cars. I’ve decided to break this process into 2 articles as I didn’t want to make a small novel on these.
Part I Side bolsters and back
The sides take much of the abuse that we dish out, every time you get in and out. They also show the damage as there is no texture. One of the most commonly damaged pieces of the seat are the side bolsters.
Mikey914
Jan 6 2016, 11:59 AM
To get o the Bolster you do need to disassemble much of the seat but if you are careful you will be able to re assemble without damaging the center upper section.
On a scale of 1-10 this is a solid 7. It’s not that it takes any incredible skill, but it requires patience and attention to detail. Particularly when re stretching the side bolsters to get then to look right. Time required per set 3 hours for just the side and back piece. Add another hour for the back if you are going that far and another for the base, as it has a few tricks you will need to make it look correct.
Tools needed
10mm socket with ratchet – set removal
Med sized standard screwdriver
#1 phillips screwdriver
5mm Allen socket or socket key – base removal
Small sharp knife (Exacto works well)
Automotive contact cement – Camie 313 is my preference
Optional –
new seat adjuster handle
chair to set the seat in while working
To begin, remove the seat from the vehicle utilizing the 10mm socket. This is most easily done by sliding it forward and taking out all 4 10mm bolts from the back of the seat rail. The height adjustment mechanism can sometimes bind it up a little, so you may find it helpful to pull the lever arm on the side back to disengage the front section of the seat if it will not come right out.
One the seat is removed you will need to take the base off .
Mikey914
Jan 6 2016, 12:01 PM
Remove the 4 allen bolts with washers and set aside for later. The seat adjuster handle need not be removed unless you are replacing yours. There is a short pictorial how to on this thread on world -
http://www.914world.com/bbs2/index.php?sho...adjuster+handleIf yours is missing, now if the time to replace it.
Once the rails are removed, you need to start to remove the old piece. The center section will need to be removed to get access to the side sections. If you keep it intact you can easily re assemble.
Mikey914
Jan 6 2016, 12:03 PM
Start by removing the 2 screws on the back of the seat at the headrest flap.
This will allow you to get at 2 hidden screws that hold the base of the headrest.
Mikey914
Jan 6 2016, 12:04 PM
At the base of the seat there is a wire that holds it down, you will need to dislodge the wire to allow the center section to come up, if not out.
There are 2 pointed prongs at the base that hold the wire on the base of the center section securely at the base. I chose to carefully bend these up using the standard flat screwdriver. You can then pull the base down to release.
With the center removed you can now have full access to remove the side bolsters.
You will want to start with the hidden prong under the front base of the seat.
Mikey914
Jan 6 2016, 12:06 PM
Then the lower base prongs,
Mikey914
Jan 6 2016, 12:07 PM
Followed by the upper section.
Once removed you will need to harvest the metal from the old piece. This is most easily done using an small sharp knife to cut the stitches.
Each side has one. Once removed, you will need to thread into the new section. Make sure the loop on the metal is at the top by the headrest, so you will feed the un looped section through from the top. This takes a little patience, and when you get to the corner you will need to be gentle as the path is more restricted and more difficult to find. With a little probing you will be able to get it through.
Mikey914
Jan 6 2016, 12:08 PM
Once you have the metal in you can begin the reassembly.
I supported the seat in a folding camping chair as I found it worked well to get it to a level that I could work and was readily available.
I started at the front base and secured the first 2 prongs on each side Making sure that I had the same amount of material on each side.
then proceeded to work my way back trying to keep the material even on each side.
Mikey914
Jan 6 2016, 12:09 PM
Continue up the side slowly making sure that you are securing it evenly as you progress. The fold on the seam in the last picture will stretch out, but your work here makes that much easier.
When this step is finished yours should look something like this.
Mikey914
Jan 6 2016, 12:11 PM
Now is the best time to secure the base back on as you will be using the contact cement to tension the vinyl. I prefer the Camie 313. Once tensioned and glued , re attach the based. Your completed product thus far will look like this.
You can use a heat gun to remove wrinkles. Or do what I did and leave in the summer sun for 3 hours.
Hope this helps
Mikey914
Jan 6 2016, 12:13 PM
For some reason I didn't see that I had showed the gluing of the back flap, but you will want to do it now to center it.
orbit398
Jan 6 2016, 03:14 PM
I recovered the seats.
I am talking about the somewhat hard interior pieces, examples: windshield piler covers & one that goes across the top of the windshield, one that goes across the top by the back window ect. Those ones, things that have a bit of foam under the somewhat hard plastic.
orbit398
Jan 6 2016, 03:15 PM
malcolm2
Jan 6 2016, 04:17 PM
QUOTE(Dion @ Jan 6 2016, 08:44 AM)
Link:
http://www.eastwood.com/vinyl-and-dashboar...CFYEmHwodyiEHcgI use that kit too. The tuff part is getting the color right. But it is not paint and does not dry until it gets heat, so you can, as mentioned above, TAKE YOUR TIME. And then there is the grain to match....
Remember that the color should be sealing the rip or filling the divot. Don't use too much or you will have a thick spot.
r_towle
Jan 6 2016, 06:03 PM
I tried two of those kits on my 911 dash with no luck.
It cracked again.
barefoot
Jan 6 2016, 06:39 PM
I had a small burn close to the interior back pad interior light repaired by a guy with a mobile service who travels auto dealerships
You have to look close to see the repair
Cairo94507
Jan 6 2016, 06:47 PM
It's vinyl. Repair it correctly and you won't have to worry about it or repair it for the next 20 plus years. Buy the kits from Mikey914.
Mikey914
Jan 6 2016, 08:14 PM
I understand the A pillars are the issue. If it's a crack you will be out of luck because of the way they were made. But, you could fill and wrap with vinyl.
Biggest problem is the foam substrate an the vinyl they used (no backing), will cause cracks due to the different rates.
orbit398
Jan 16 2016, 08:12 PM
QUOTE(orbit398 @ Jan 6 2016, 08:31 AM)
added some pics of what I am trying to repair
