OT / calling electrical GURU's |
914itis |
Jan 10 2016, 04:13 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am wiring my garage heater . 220 Volts
I have a 220 outlet in the garage but I will need to hard wire the heater, I am posting pictures of both, the heater connectors and the outlet, As I understand L1 is black and L2 to red, Ground to ground, What about the white wire? Thanks in advance. Attached image(s) |
fixer34 |
Jan 10 2016, 05:33 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
White is not the same as ground even though they are bonded at the circuit breaker box. If you don't need the white/neutral on the heater, tape the wire off and fold it back. It looks like you are running a Romex (plastic) type cable; be VERY sure that the green/ground wire is securely connected at both ends and to a good building ground point like a cold water pipe.
Also curious why you need to hard wire it in. If you already have a 220v outlet, can't you make up a short cord with a plug? If not, also install a circuit breaker/disconnect in the garage by the heater. You don't want to be running to the basement in a hurry if it starts smoking/burning. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:03 PM |
