OT / calling electrical GURU's |
914itis |
Jan 10 2016, 04:13 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am wiring my garage heater . 220 Volts
I have a 220 outlet in the garage but I will need to hard wire the heater, I am posting pictures of both, the heater connectors and the outlet, As I understand L1 is black and L2 to red, Ground to ground, What about the white wire? Thanks in advance. Attached image(s) |
stugray |
Jan 11 2016, 09:17 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
In the second pic (of the plug) it looks like the white & Ground are connected together. That is incorrect (at the plug end).
White and Ground ARE the same but only AT the breaker panel. They can never be connected together anywhere else. For a three prong 220V plug, the only wires required are: Phase1(hot-blk), Phase2(hot-red), GND (green). No neutral wire is used in a 3 prong. If the circuit needs to be hardwired at the panel, then you will need two open breaker slots, one on each phase. One of these will hook to red, and snap into the panel Another of these will hook to black, and snap into the panel The Ground will hook to the Ground bus bar in the panel. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:36 AM |
