North Coast Jim |
Member ![]() ![]() Group: Members Posts: 340 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
Looking for any information about location of the fuel pump for a carb converted 914. Under the gas tank I assume since a low pressure pump needs good head pressure to operate correctly. With that said is there a preferred pump to use. What tubing/hose is everyone using for transiting the tunnel. Braided or a thick walled high pressure rubber fuel line. I've looked for threads within the site but didn't find any although I'm still learning the site. Any help is appreciated
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I have had this same pump on my car for 12 years. It has ALWAYS been mounted where you see it in the bottom of this picture. Never had a problem with low head pressure. Never had a vapor lock problem with this 3psi pump. It feeds a 2.2 liter type IV with 44idf Webers. YMMV (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) ![]() ![]() |
02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
I have had this same pump on my car for 12 years. It has ALWAYS been mounted where you see it in the bottom of this picture. Never had a problem with low head pressure. Never had a vapor lock problem with this 3psi pump. It feeds a 2.2 liter type IV with 44idf Webers. YMMV (IMG:style_emoticons/default/biggrin.gif) you don't have any problems with Vapor lock??? with the install in the stock OEM location?? |
Lo-Fi Version | Time is now: 12th July 2025 - 03:14 PM |
