Rocker Panel Rivetts, Are they available |
jack20 |
Dec 19 2014, 09:40 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I want to remove my rockers, straighten and paint, then re-attach. Does any know where to buy the rivets? What about size and material? Can they be attached with a pop rivet tool?
Thanks, Jack |
Mikey914 |
Jan 17 2016, 02:30 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the threasholds on the 914 early style should be a clear rivet. The rocker panels are metal.
However, some of the 911s use these plastic rivets to secure a molding on the side also. So there is a crossover. Also let me know if there was a mistake on your order and you wanted the plastic. I'll take care of you. I haven't listed these yet but will later this week. Mark |
porbmw |
Jan 17 2016, 07:03 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Yes the threasholds on the 914 early style should be a clear rivet. The rocker panels are metal. However, some of the 911s use these plastic rivets to secure a molding on the side also. So there is a crossover. Also let me know if there was a mistake on your order and you wanted the plastic. I'll take care of you. I haven't listed these yet but will later this week. Mark My car has been apart a long time...and I am getting old(er) BUT I am pretty sure that the ROCKERS were affixed with metal rivets (and the rockers can be cleaned out\ to removing the screws/bolts, whatever you want to call them, that attach the rockers to the underbelly of the car. Most of the debris will fall out once those are detached, and a screwdriver or other implement can persuade the bulk of whatever else has been caught up, underneath/inside. The thresholds were/are held in by plastic rivets...I believe more of a semi clear than a white, in the early years, and black later on. |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:43 PM |
