| mb911 |
Dec 9 2015, 10:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Guys,
I need to have some fittings machined and wanted to know what the factory 914-6 oil tank fittings are suppose to be? |
| mb911 |
Jan 18 2016, 12:40 PM
Boy I thought there would be some excitement for this or at least some feedback..
I think I may powder coat them black just like dwd did?? I will hopefully have a production unit done this week.. |
mb911 914-6 oil tank fittings Dec 9 2015, 10:20 AM
screenguy914 The cost to create fittings from scratch might be ... Dec 9 2015, 10:41 AM
mb911
The cost to create fittings from scratch might be... Dec 9 2015, 10:56 AM
porschetub
The cost to create fittings from scratch might b... Dec 9 2015, 12:55 PM
mb911 I will probably offer them both ways.. Just want t... Dec 9 2015, 04:41 PM
jfort I have AN Dec 9 2015, 04:45 PM
rgalla9146 The attached image has non- original fittings to t... Dec 9 2015, 07:54 PM
Mark Henry Personally if the tank is not correct then use mor... Dec 12 2015, 12:18 AM
porschetub
Personally if the tank is not correct then use mo... Dec 12 2015, 02:53 AM
rgalla9146
Personally if the tank is not correct then use m... Dec 12 2015, 05:08 PM
Mark Henry
[quote name='porschetub' post='2276220' date='Dec... Dec 12 2015, 08:20 PM
Mikey914 You may want to take a part an original, as they a... Dec 13 2015, 02:40 PM
mepstein Ben - I can't offer to have you take apart my ... Dec 13 2015, 02:57 PM
Mark Henry I can show you a 72 911 tank that was cut open.
T... Dec 13 2015, 04:13 PM
rgalla9146
... Dec 13 2015, 05:32 PM
Mark Henry
[quote name='Mark Henry' post='2276785' date='Dec... Dec 13 2015, 08:39 PM
jmill I looked into it a while ago. Links for the tank ... Dec 13 2015, 04:23 PM
mb911
I looked into it a while ago. Links for the tank... Dec 13 2015, 06:53 PM
worn
[quote name='jmill' post='2276788' date='Dec 13 2... Jan 27 2016, 12:44 PM
mb911 Wow didn't check for a couple days and now all... Dec 13 2015, 06:05 PM
jmill
[quote name='jmill' post='2276788' date='Dec 13 2... Dec 14 2015, 09:53 AM
Eric_Shea You Cheeseheads get together over a couple-a brats... Dec 14 2015, 11:58 AM
mb911 I actually work at the local tech college as a wel... Dec 14 2015, 02:39 PM
jmill I'm in the market for an aluminum tank without... Dec 14 2015, 05:05 PM
mb911
I'm in the market for an aluminum tank withou... Dec 14 2015, 05:17 PM
mb911 here is a rough template. I will test fit over the... Dec 15 2015, 11:03 AM
jmill Looking good. If you're going to mass produce... Dec 15 2015, 04:38 PM
mb911
Looking good. If you're going to mass produc... Dec 15 2015, 07:11 PM
mb911
Looking good. If you're going to mass produ... Dec 16 2015, 06:22 AM
mb911
Looking good. If you're going to mass produ... Dec 16 2015, 10:46 AM
mb911 Ok another question for all of you. The oil line ... Dec 16 2015, 06:22 PM
mb911 Here is the first revision to the plug/template an... Dec 17 2015, 10:42 AM
mb911 and a comparison. may still need to revise more bu... Dec 17 2015, 11:51 AM
mb911 Ok another update. The revision fits in perfect.. ... Dec 17 2015, 02:30 PM
396
Ok another update. The revision fits in perfect..... Dec 17 2015, 07:10 PM
mb911
Ok another update. The revision fits in perfect.... Dec 17 2015, 07:18 PM
brant tank looks good
I made the same one about 5 years... Dec 17 2015, 03:10 PM
mb911 It's ok I needed to do it from scratch for a s... Dec 17 2015, 03:15 PM
brant I kept the internal baffling and internal screen b... Dec 17 2015, 03:58 PM
Eric_Shea A drain cock would be much appreciated.
Excellent... Dec 17 2015, 04:23 PM
mb911
Excellen... Dec 17 2015, 05:04 PM
Eric_Shea I can send you one.
This is what I was thinking. ... Dec 17 2015, 06:02 PM
mb911
I can send you one.
This is what I was thinking.... Dec 17 2015, 06:32 PM
brant pictures of the one I made about 8 years back..
a... Dec 17 2015, 07:21 PM
brant and Dec 17 2015, 07:22 PM
brant last: Dec 17 2015, 07:23 PM
mb911 It's hard to tell from the picture but is that... Dec 17 2015, 07:30 PM
brant
It's hard to tell from the picture but is tha... Dec 17 2015, 07:57 PM
wndsnd Wow, you guys are some talented mofos. :)
I wi... Dec 17 2015, 08:00 PM
mb911 I am really excited to be back in the game and wil... Dec 17 2015, 09:56 PM
mb911 Another question for you is of all the tanks out t... Dec 27 2015, 02:26 PM
Eric_Shea No issues whatsoever... Dec 28 2015, 12:14 PM
Mark Henry Is that screen stainless steel? or what is it mad... Dec 28 2015, 01:40 PM
mb911
Is that screen stainless steel? or what is it ma... Dec 28 2015, 01:57 PM
jmill If you do install a baffle I would recommend a dif... Dec 28 2015, 01:56 PM
mb911
If you do install a baffle I would recommend a di... Dec 28 2015, 02:06 PM
sixnotfour .750 would be an improvement .. and make filter co... Dec 28 2015, 02:00 PM
mb911
.750 would be an improvement .. and make filter c... Dec 28 2015, 02:03 PM
jmill You can add tabs. Cut two slots in the backside a... Dec 28 2015, 02:22 PM
jmill Ugly pic but you'll get the idea. Dec 28 2015, 02:29 PM
Mark Henry I'm less concerned with the baffle, as long as... Dec 28 2015, 02:55 PM
mb911
I'm less concerned with the baffle, as long a... Dec 28 2015, 03:35 PM
mb911
I'm less concerned with the baffle, as long ... Jan 4 2016, 03:23 PM
mb911 I am ordering fittings today have all of you decid... Jan 7 2016, 08:49 AM
Mark Henry
I am ordering fittings today have all of you deci... Jan 7 2016, 09:06 AM
mb911
I am ordering fittings today have all of you dec... Jan 7 2016, 09:13 AM
jd74914 I like the ideal of female standard fittings a wel... Jan 7 2016, 11:20 AM
jmill I can see why PMS went with M22. You can readily ... Jan 7 2016, 12:45 PM
jmill
You could just leave it at that, as there is metr... Jan 7 2016, 01:11 PM
mb911
You could just leave it at that, as there is met... Jan 7 2016, 07:36 PM
jmill
We should just do yours in straight AN way easier... Jan 7 2016, 08:53 PM
mb911 Ok I have researched it like crazy 22mm is the bes... Jan 9 2016, 11:54 AM
mb911 So quick update this is the final transfer pattern... Jan 13 2016, 07:18 PM
mb911 1st one for jmill and remote oil filter set up Jan 17 2016, 06:06 PM
mb911 I used baffle specd by customer production units w... Jan 17 2016, 06:09 PM
mb911 Tank ready for -12 weld on bungs Jan 17 2016, 06:10 PM
jmill Heck, I'm all kinds of excited! :wub:
... Jan 18 2016, 01:04 PM
mepstein Powder coat looks nice but chances are it's go... Jan 18 2016, 01:14 PM
jd74914 That looks nice! I like that the baffles are w... Jan 18 2016, 01:36 PM
Eric_Shea
Aluminum, like steel or cast iron, needs to be p... Jan 18 2016, 01:49 PM
Aluminum, like steel or cast iron, needs to be ... Jan 18 2016, 02:26 PM
worn
Aluminum, like steel or cast iron, needs to be... Jan 27 2016, 01:53 PM
mb911
[quote name='mepstein' post='2291143' date='Jan 1... Jan 27 2016, 02:21 PM
mb911 All good points.. I did choose 5052 h32 for 2 reas... Jan 18 2016, 02:53 PM
porschetub
All good points.. I did choose 5052 h32 for 2 rea... Feb 16 2016, 12:50 AM
MJHanna Anodizing is not any more cost than powder coating... Jan 18 2016, 03:02 PM
mb911
Anodizing is not any more cost than powder coatin... Jan 18 2016, 04:18 PM
BigD9146gt Good'ay guys...
I only skimmed this so please... Jan 24 2016, 10:55 PM
mb911
Good'ay guys...
I only skimmed this so pleas... Jan 27 2016, 10:47 AM
Mark Henry I agree and that is the conclusion I came to as w... Jan 27 2016, 02:40 PM
mb911
I agree and that is the conclusion I came to as ... Jan 27 2016, 04:45 PM
jmill
Thick powder coat, like what my PC guy does on bl... Jan 27 2016, 02:48 PM
mb911 Here is number 1 of the oil tanks with oil filter ... Feb 8 2016, 12:47 PM
jd74914 That looks like it fits really nice! Feb 8 2016, 01:48 PM
johnhora :agree:
Very nice! Feb 8 2016, 02:03 PM
mb911 Thanks.. I appreciate the support.. Going to revis... Feb 8 2016, 02:53 PM
mb911 Took off a half day today to finish up some tanks ... Feb 15 2016, 03:56 PM
restore2seater Since you're shipping them, does that mean you... Feb 15 2016, 10:46 PM
Steve Looking forward to the heat exchangers!! Feb 16 2016, 12:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:17 PM |
