| Amphicar770 |
Jan 19 2016, 12:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
Hi all,
I have read conflicting info: Some say that you should not reuse flywheel bolts Others say to reuse them with some loctite blue and all is good. Seems obscene that these are $10+ each bolt. It looks like a number of Toyota equivalents are also M10 x 1.25, what I can not find is the length of the Porsche bolts. Seems like something like these should work if you can get the right length? http://www.ebay.com/itm/ARP-M10-x-1-25-x-2...8ah&vxp=mtr Thoughts? |
| McMark |
Jan 20 2016, 08:02 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Cap'n Krusty says, reuse 4cyl bolts, replace 6cyl bolts. Final answer. (IMG:style_emoticons/default/wink.gif)
Amphicar770 Flywheel Bolts Jan 19 2016, 12:01 PM
r_towle I have never replaced them, I always re use them.
... Jan 19 2016, 12:07 PM
porschetub
I have never replaced them, I always re use them.... Jan 20 2016, 04:24 PM
brant 4 or 6 cylinder?
I always re use 4 cylinder
I... Jan 19 2016, 12:12 PM
stugray Reuse and flip the "six shooter" gasket ... Jan 19 2016, 01:47 PM
ThePaintedMan That makes sense. I knew the aluminum crush washer... Jan 19 2016, 01:57 PM
mepstein Our Porsche 962 mechanic said you never reuse flyw... Jan 19 2016, 02:07 PM
wndsrfr
Our Porsche 962 mechanic said you never reuse fly... Jan 20 2016, 09:01 PM
Amphicar770 Mine is a 2.0, 4-banger, so sounds like reuse is g... Jan 19 2016, 02:28 PM
brant Got to use a torch to release red loctite
A 600ft ... Jan 20 2016, 11:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:02 PM |
