| Amphicar770 |
Jan 19 2016, 12:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
Hi all,
I have read conflicting info: Some say that you should not reuse flywheel bolts Others say to reuse them with some loctite blue and all is good. Seems obscene that these are $10+ each bolt. It looks like a number of Toyota equivalents are also M10 x 1.25, what I can not find is the length of the Porsche bolts. Seems like something like these should work if you can get the right length? http://www.ebay.com/itm/ARP-M10-x-1-25-x-2...8ah&vxp=mtr Thoughts? |
| mepstein |
Jan 19 2016, 02:07 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Our Porsche 962 mechanic said you never reuse flywheel bolts on a 6.
| wndsrfr |
Jan 20 2016, 09:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Our Porsche 962 mechanic said you never reuse flywheel bolts on a 6. That's IF you can even remove those %#@&king 12 point bolts on a 6 given that I think red loctite is on some of them. Had a hell of a time getting two of them out that stripped the 12 point head, so tried an ez out which required grinding off the outer rim of the pilot bearing first... Ended up grinding the threads out of a nut and welding it on to the bolt head to get them out....Yecccch Definitely NOT reusable! |
Amphicar770 Flywheel Bolts Jan 19 2016, 12:01 PM
r_towle I have never replaced them, I always re use them.
... Jan 19 2016, 12:07 PM
porschetub
I have never replaced them, I always re use them.... Jan 20 2016, 04:24 PM
brant 4 or 6 cylinder?
I always re use 4 cylinder
I... Jan 19 2016, 12:12 PM
stugray Reuse and flip the "six shooter" gasket ... Jan 19 2016, 01:47 PM
ThePaintedMan That makes sense. I knew the aluminum crush washer... Jan 19 2016, 01:57 PM
Amphicar770 Mine is a 2.0, 4-banger, so sounds like reuse is g... Jan 19 2016, 02:28 PM
McMark Cap'n Krusty says, reuse 4cyl bolts, replace 6... Jan 20 2016, 08:02 PM
brant Got to use a torch to release red loctite
A 600ft ... Jan 20 2016, 11:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:02 PM |
