| 80cap |
Jan 24 2016, 07:54 AM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Is the heavy rubber like fire wall liner necessary or does dynomat or
similar sound mat just as good? Thanks Brian (IMG:style_emoticons/default/confused24.gif) |
| Garland |
Jan 24 2016, 09:26 AM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Here's a factory pad. I'm debating what to use to attach it with. I'm thinking something other then glue, any ideas?
| r_towle |
Jan 24 2016, 04:15 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Here's a factory pad. I'm debating what to use to attach it with. I'm thinking something other then glue, any ideas? ![]() ![]() That rubber piece does two things It blocks a specific set of sound frequencies. It blocks noisy vibration if firmly attached to the firewall. So, how you attach it will determine how good it works. Noise is both sound frequencies and sound vibration.... Velcro (the 3m command strips are very strong) may be a choice that could work. |
80cap Fire wall liner Jan 24 2016, 07:54 AM
dflesburg we use hood liner in the engine bay and dyno mat i... Jan 24 2016, 08:34 AM
80cap What is hood liner?
Brian Jan 24 2016, 08:39 AM
cary Here's what 914 Rubber sells.
http://shop.914r... Jan 24 2016, 10:47 AM
Mikey914 I also have the rubber aircraft firewall material ... Jan 24 2016, 12:12 PM
80cap The 914 rubber pad goes on the engine side.
The on... Jan 24 2016, 12:13 PM
saigon71 I went with Rattle Trap on the inside (similar to ... Jan 24 2016, 02:16 PM
Dave_Darling Early 914s and 914-6es did not have the pad on the... Jan 24 2016, 04:18 PM
Garland Went ahead and glued it on, used 3M super 77 both ... Jan 24 2016, 04:28 PM
r_towle Cool, that will work. Jan 24 2016, 05:07 PM
dflesburg hood liner is like dyno mat but thermal and thicke... Jan 24 2016, 05:20 PM
dflesburg http://www.amazon.com/Dynamat-11905-Hoodli...r/dp/... Jan 24 2016, 05:20 PM
Larmo63 I took Dave's advice, and just now ripped all ... Jan 24 2016, 11:51 PM
Mikey914 Sorry, thought you were talking about the engine s... Jan 25 2016, 12:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:53 AM |
