| lsintampa |
Jan 26 2016, 03:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I'm in the middle of rebuilding my dash.
I'm using the following parts (all from 914 rubber - Thanks Mark!) New top dash. New top padding and vinyl that goes on the top between the windshield and back of the dash top. New rubber seal for inside front windshield to dash top. New dash face metal and vinyl. I removed the steel dash frame - as it made a lot of sense to me. It appears I can assemble the whole dash (all the parts above - except the seal that would go on last) onto the steel frame, and then install the whole assembled dash in the car. Then finally install the windshield seal. AS OPPOSED TO - putting the steel frame back in - then putting the dash on the frame, etc. Bottom line is putting the dash onto the frame and then into the car - seems to me to be a whole lot easier to do. Has anyone done it that way? Thanks, Len |
| Darren C |
Jan 27 2016, 02:12 PM
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Yep,
As you said you can rebuild the whole dash out of the car. Just leave off the Knee Roll to allow you to refit it. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1453925534.1.jpg) It's makes for easier access but it's a big job disconnecting everything, then putting it all back just for trimming purposes. The real benefit is you can glue the vinyl sheet material on well and fold the edges under (along the base of the screen and around the vents) and glue them down for a better job. (You cant do this with it in the car) |
| Marktini |
Jan 30 2016, 09:22 AM
Newbie ![]() Group: Members Posts: 5 Joined: 31-July 15 From: Chicago Member No.: 19,016 Region Association: Upper MidWest |
lsintampa Has Anyone Done This? Jan 26 2016, 03:32 PM
r_towle I do not think it will fit.
If it does, please sh... Jan 26 2016, 04:44 PM
Garold Shaffer I haven't installed one, but I have parted my ... Jan 26 2016, 05:05 PM
Chris914n6 It is easier with the top pad attached. The bottom... Jan 26 2016, 05:40 PM
lsintampa Well, here's the deal.
Both a-pillars off, bo... Jan 26 2016, 06:36 PM
r_towle Nice Jan 26 2016, 06:47 PM
Krieger What about all the wiring for the gauges? I think... Jan 27 2016, 12:37 AM
lsintampa
What about all the wiring for the gauges? I thin... Jan 27 2016, 07:37 AM
r_towle Can the whole dash be pulled out this way?
I have ... Jan 30 2016, 11:11 AM
Darren C
I have... Jan 30 2016, 11:56 AM
lsintampa
I have... Jan 30 2016, 12:38 PM
r_towle Anyone post some pics of the fasteners that hold t... Jan 30 2016, 01:50 PM
Darren C To remove the WHOLE dash....There are 4 x M6 nuts ... Jan 30 2016, 02:24 PM
Travis Neff I would imagine when these cars were put together ... Jan 30 2016, 04:04 PM
mepstein Cool thread. I eventually have to tear apart my da... Jan 30 2016, 04:19 PM
Rob-O Probably the most difficult part of this is the he... Jan 30 2016, 09:52 PM
r_towle I am really happy to learn this. Jan 30 2016, 10:42 PM
RobW Does this make sense to pull the dash and work on ... Jan 31 2016, 06:55 AM
McMark
Does this make sense to pull the dash and work on... Jan 31 2016, 08:25 AM
3d914 Len or Darren, did you have to have the windshield... Jan 31 2016, 05:11 PM
Darren C You should be able to get the dash out with the wi... Feb 1 2016, 03:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:54 PM |
