How I made my windshield valence |
Bill's Racing 914 |
Feb 2 2016, 12:10 PM
Member Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None |
I made the original shape out of 2inch thick yellow wall insulation foam I bought at Home Depot. You can see the outline in the plaster mold.
I used the glass windshield I removed from the car as the guide for the knife I used to cut the leading edge radius. To make the mold, I used 5 layers of plaster of paris and reinforced with red shop rags. To finish the surface, I applied a thin layer of CUZ blue body filler and sanded with 80 grit sandpaper and a sanding block to keep it from coming out wavey. Then I applied six to seven coats of sandable body primer. I used 320 grit sand paper to wet sand each layer with a sanding block. It came out looking like grey gelcoat. (IMG:style_emoticons/default/welder.gif) Attached thumbnail(s) |
Cory M |
Feb 2 2016, 02:48 PM
Newbie Group: Members Posts: 19 Joined: 31-March 06 From: san diego Member No.: 5,798 |
Looks good. Appears to provide more room in the cab and for your hands than the Ginther screens I've seen.
Lo-Fi Version | Time is now: 8th June 2024 - 06:38 AM |
