Re-using stock oil pump on a stock-ish rebuild |
saigon71 |
Feb 3 2016, 02:47 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Pulled my stock oil pump apart and gave it a close inspection. The internals look great with little discernable wear. The only real wear spot I found were slight marks on the drive tang from the cam gear.
The engine I'm building will be a stock-ish 1971 or 2056 with a stock cam or a cam slightly more aggressive than stock. Stock D-jet FI. No external oil cooler. Any issues re-suing the stock oil pump? |
r_towle |
Feb 3 2016, 04:22 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The main issue, aside from the internals not being healthy, is the inlet and outlet holes in both the pump and the case have very sharp edges which can aid in decreased oil pressure, especially at lower rpms.
If you ease those edges, and get the Foley spring.....should be more than enough oil pressure. rich |
Lo-Fi Version | Time is now: 10th June 2024 - 03:50 AM |
