saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
Pulled my stock oil pump apart and gave it a close inspection. The internals look great with little discernable wear. The only real wear spot I found were slight marks on the drive tang from the cam gear.
The engine I'm building will be a stock-ish 1971 or 2056 with a stock cam or a cam slightly more aggressive than stock. Stock D-jet FI. No external oil cooler. Any issues re-suing the stock oil pump? ![]() ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Pulled my stock oil pump apart and gave it a close inspection. The internals look great with little discernable wear. The only real wear spot I found were slight marks on the drive tang from the cam gear. The engine I'm building will be a stock-ish 1971 or 2056 with a stock cam or a cam slightly more aggressive than stock. Stock D-jet FI. No external oil cooler. Any issues re-suing the stock oil pump? ![]() ![]() It fine to use again (IMG:style_emoticons/default/beer.gif) ,oil filter helps here...not like type 1 motors that chew out pumps. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:36 PM |
