How I made my windshield valence |
Bill's Racing 914 |
Feb 2 2016, 12:10 PM
Member Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None |
I made the original shape out of 2inch thick yellow wall insulation foam I bought at Home Depot. You can see the outline in the plaster mold.
I used the glass windshield I removed from the car as the guide for the knife I used to cut the leading edge radius. To make the mold, I used 5 layers of plaster of paris and reinforced with red shop rags. To finish the surface, I applied a thin layer of CUZ blue body filler and sanded with 80 grit sandpaper and a sanding block to keep it from coming out wavey. Then I applied six to seven coats of sandable body primer. I used 320 grit sand paper to wet sand each layer with a sanding block. It came out looking like grey gelcoat. (IMG:style_emoticons/default/welder.gif) Attached thumbnail(s) |
brant |
Feb 4 2016, 12:34 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The problem is that some of the old rules require a tansluscent wind screen. Thus svra adopted that requirement
Bill's Racing 914 |
Feb 4 2016, 10:06 AM
The problem is that some of the old rules require a tansluscent wind screen. Thus svra adopted that requirement Here is 914-6 racing at Willow Springs with VARA with a similar design... Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:44 PM |
